Results 1 to 20 of 26
Thread: Air Lid/ Austin ssra kit ?s
11-17-2007, 12:57 PM #1Army Dude
- Nov 2007
- Ft. Rucker Area, Lower AL
Arctic White- 01 TA / 06 Duc 749D
does anyone know where i can find one of those clear air lids? also wondering if anyone has used the Austin super sucker ram air kit. couldn't bring myself to install a Pontiac hood on my Z28, and the Z hoods don't look much different. so i figured i could go with this kit and still get most of the ram air effect. any input on thiese ?sss would be great.
11-17-2007, 01:19 PM #2
11-17-2007, 03:07 PM #3
i just installed the ssra add on piece today. i originally just had the slp cold air induction then ordered the add on piece. i actually wanted to test to see how much more air went in. so i took the air filter out and put ur typical bedroom fan and place it right under my grill. i took the airlid off and turned the fan on. this was without the ssra addon. and barely felt any air(i barely felt anything from the top of cai where the lid was. prolly cuz its a weak ass fan. i imagine going 50+ or on the freeway where the air is rushing under ur car. but then i put the add on piece from the ssra and then put my hand at the same place where the airlid is and i could feel more air and a more consistent flow. so it def. gets that cold air up there. i imagine going on the freeway with all the air rushing that a lot more cold air will be rushing to ur engine. i ahvent drove it yet. cuz i just barely finished the install literally 15 mins ago.i imagine i wont feel a lot fo throttle response, but might see gains on the dyno or a higher trap speed at the track. after i drove it i will let u know if i felt a throttle difference
11-17-2007, 04:36 PM #4
yup, like i've always said. the ssra is far superior to the slp peice. anyone out there in the market for a cai kit should seriously consider it.
11-17-2007, 04:46 PM #5
Pics? Link?
11-17-2007, 07:18 PM #6
well i took the car out for a lil cruise and i def felt more uptop!!! the car seemed to pick up quick when downshifting from 4th to 2nd and from 3rd to 1st. i have my lca relocation brackets to put on to get some more traction, cuz my wheels seem to be spinning a little more. but yea it was about 60 degrees outside and its kinda nice knowing ur engine is getting the coldest air possible. two thumbs up for this product. i jsut have to watch out a little more when going over bumps and my steep driveway but it is well worth. i want to get my car dynoed now. o yea i took the air filter out as well no ihave no restritions at all. i even took out the maf screen. o man the car IS FINALLY BREATHING!!!
11-17-2007, 07:21 PM #7
11-17-2007, 07:45 PM #8
I just installed the austin ram air tonight on my car. Beforehand i had just the slp flowpac, so this piece fit right into it and screwed in just fine. It feels a little more responsive up top, i can hear a mild sucking of air when i rev it. I'd recommend it
11-17-2007, 09:50 PM #9
11-18-2007, 09:05 AM #10Army Dude
- Nov 2007
welli'm sold. i figured this would test out fine. is there any gap where the two peices join together? anyways. looks like it sits as low as the front deflector. well thanks for the input.
11-18-2007, 02:28 PM #11
there is a gap. well there has to be one in between pieces cuz there is ur hood latch that needs to connect. what i did was with whatever gap was there, i just covered it with duct tape. meanwhile i gave more support up top with some tape. but i had the addon piece, but if u get the ssra as one it might b a li different but i imagine its about the same gap.
11-18-2007, 06:23 PM #12Army Dude
- Nov 2007
do they make a plug for the bottom or a plate for the top in case of rain? doesn't say in the details of the kit if something like that is included.
11-18-2007, 08:41 PM #13
11-18-2007, 09:18 PM #14
In rain you should be fine, i've seen pieces of plastic sold online somewhere that fit it, but you could always make something your self just to fit under the filter.
11-19-2007, 07:09 AM #15Army Dude
- Nov 2007
yeah clarksville is nice but can kinda be a ghost town when we all deploy. been stationed here since 02. anyways, a buddy of mine tells me there is a piece that can be bought but its kind of a pain to install because it screws down under the filtewr. i'll probably buy a case of beer for the guys in the sheet metal shop to make somethinng that will slide back and forth.
11-22-2007, 06:40 PM #16
the gap is there in case of rain. it allows any water that happens to get sucked up to go out the back and not into the filter. i wouldnt recommend covering the gap up with tape because you only lose a small amount of air and it's a preventative measure against water getting in. although if you never drive in the rain like the guy above go ahead and tape it off.
11-22-2007, 07:22 PM #17Army Dude
- Nov 2007
thanks dude, you just saved me a case of beer.
11-22-2007, 08:31 PM #18
11-24-2007, 03:04 PM #19Army Dude
- Nov 2007
look it up yourself dude. i found it at LMPerformance.com it's called the Austin SSRA kit. and when you find the picture, you post it up if you like. i've already got the worthless info i needed.
11-24-2007, 03:27 PM #20
SSRA, should buy it.
By karpetcm in forum External EngineReplies: 44Last Post: 06-07-2010, 06:41 PM -
Ssra
By IT_SS in forum External EngineReplies: 10Last Post: 03-23-2009, 09:06 AM -
ssra
By 02Sweet in forum Internal EngineReplies: 2Last Post: 10-17-2008, 07:36 PM -
wtb ftra or ssra
By c5z28 in forum Parts Wanted / TradeReplies: 2Last Post: 10-11-2008, 02:59 PM -
Austin SSRA Kit???
By Buckeye221 in forum External EngineReplies: 6Last Post: 02-22-2008, 12:33 PM
