Results 1 to 18 of 18
    Boston
    Removing Side Moldings
    I want to remove the side moldings on my Z, but I'm worried about the glue under them. I peeled back a little bit of one of the molds and it looks too thick like it wont come off. I thought about goo gone but I'm also worried about removing my paint. O yea I was also wondering if the paint under the moldings would be darker due to the sun not getting to it.
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    i was thinking the exact same idea...when ever you get your next retouch..just make sure to tell the painter to take it off,thats what i did...
    doylestown, Pa
    SILVER
    2004 CTS-V
    Welcome to LS1.com!!
    Your car is black. It should not be an issue. The glue will come off with 3M adhessive remover, but it will take some work. Make sure that your car has never been repainted because some shops will take short-cuts by not removing the molding and painting over it.
    eating bulldog
    son of biscuit
    or that
    Boston
    sweet. I'll prob end up taking it all off then. thanks guys
    Minnesota
    Black---NBM
    1991 z-28---2000 z-28
    Your car is black. It should not be an issue. The glue will come off with 3M adhessive remover, but it will take some work. Make sure that your car has never been repainted because some shops will take short-cuts by not removing the molding and painting over it.[/QUOTE]
    thats what happened to me. I found some runs under mine, but it looked better because my car was missing a couple of trim pieces when I got it.
    TN
    they also make a eraser wheel that you can put on a drill that will pull it right off easy without hurtin the paint
    Member ghettosled's Avatar
    cleveland, ohio
    pewter
    1999 camaro ss #4288
    i have a pewter car and with the help of a heat gun, most of the adhesive came off with the moldings. the rest of the adhesive i removed with goo-gone. the car looks much cleaner without the moldings.
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Quote Originally Posted by ghettosled View Post
    I did mine the same way.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    I went to Playboy Mansion FantaZGuy28's Avatar
    Bakersfield/Long Beach Ca
    YJ
    04 GTO M6
    Heat gun, where I come from we call those hair dryers haha.
    Thats what I used when I removed the molding on my Z28. The glue should rub off if its still hot with your thumb and clay bar it afterwards and it should be good as new.
    SS Driver aerojt's Avatar
    Ohio
    1998 Camaro SS M6 #1871
    any pics of these cars?
    YJ
    04 GTO M6
    Ewing, NJ
    1969 Z28 JL8 crossram, #'
    I need to take those moldings off my SS but I'm always working on something else. And I keep thinking they might save the car in my parking lot at work some day.
    1969 Z28 JL8 4 wheel disc brakes, crossram, #'s matching - being restored
    The Masterpiece Qwk94Z28's Avatar
    michigan
    SOM
    1998 Z28-408 l92 stroker
    i used a hairdryer on mine and goo gone, but man it was rough getting that glue off
    doylestown, Pa
    SILVER
    2004 CTS-V
    Yellow frog?
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    this is easy? just like stated use your thumb to remove the glue
    DFW
    '18 CTS-V
    '13 ZL1
    here is my entire write up about removing the side molding. i suggest that you look in the APPEARANCE SECTION FORUM next time for threads covering this sort of stuff...
    http://www.ls1.com/forums/showthread.php?t=49240
    Georgia
    2014 Camaro 1LS
    I keep mine on. On black cars the side molding doesnt show up as bad as other colors. Mine saved me a dent in the side at least once that I know of.
  1. side moldings..
    By 98maro in forum Appearance Section
    Last Post: 08-11-2011, 12:20 AM
  2. Side moldings
    By REVNORR82 in forum GM Trucks
    Last Post: 06-02-2011, 09:29 AM
  3. Shaved side moldings
    By redrocketws6 in forum Firebird / WS6
    Last Post: 10-25-2010, 05:14 AM
  4. Question: Body Side Moldings
    By ShawnShaggy in forum Appearance Section
    Last Post: 06-04-2009, 11:35 AM
  5. Outside side door moldings
    By FireRescueWS6 in forum Appearance Section
    Last Post: 01-16-2008, 11:02 AM
