11-14-2007, 04:06 PM #1
"Street Tune" Question.. Need answer quick!
Hey guys.. I have a 00 t/a with full exhaust including long tubes.. and a lid. Well the performance shop down the street from my house is Quality Custom Racing, the guy that owns it is Sam Stevenson and he is known around here for LS1 car's and only deals in LS1 cars... Well I am taking my car to him to have him do his "tune" on it with the air fuel's and stuff... Well he was talking if I already had my 02 bung... What is he talking about? Is this something I need to get? I don't have any rear oxygen sensors, I have 2 fronts.. No cats, No EGR, No Air pump system... Last time I took him my car he deleted all my PO Codes so I don't have a SES light... Well my question is can I get a detailed description about the 02 Bung he was talking about?
11-15-2007, 04:36 AM #2
Why dont you contact him directly and ask him? An 02 bung is Where your 02 sensors screw into on your Lt's. Maybe he was askin if you have a wideband?
11-15-2007, 04:40 AM #3
Well I did talk to him about it and he was talking about a couple of rubber plugs right where the passengers in the backseat feet go... he said its easy to just hook up through there since there is already holes... he said we can just tape all your wires up and tuck them there and you wouldn't know they were there... So at that point I was just confused and told him "Okay"... He is going to tune it on LS1 edit I think because its not a dyno tune.. Does anyone know what he is talking about?
11-15-2007, 05:19 PM #4
what he is getting at is if you have an o2 bung in the exhaust somewhere, so he can install his wideband to tune with. the o2 bung is that thing where the o2s screw into. do you still have the rears in? or when you did your exhaust, remove them?
also, the rubber plugs are the under the carpet. GM put these in, so you can drain the car out of water when it gets filled up. say from leaviong a window open and water filling up where your feet go.
this is what he's getting at. back when i had an electric cutout, i used the rubber grommet hole to run the wires
11-16-2007, 07:53 PM #5Member
- Oct 2005
- calif.
Yes--asking if you have an 02 bung to install the wideband 02 sensor in to do a more accurate tune--it needs to be Pre-cat--as close to the collector as possible--as if you can above the "3 & 9 o'clock positions--He can do a narrow band tune with your narrow band stock 02's but it's nowwhere near as accurate and he'll have to error on the side of rich to be safe--and its won't be the optimum---
"Yoof"/Thugs Beat U.S. Army Soldier on Street - Tampa (vid)
By wileyCoyote in forum Political / Debate ForumReplies: 5Last Post: 05-15-2012, 01:49 PM -
Quick "newbie to tuning" question
By PON-TON in forum Computer & TuningReplies: 0Last Post: 04-08-2011, 10:57 AM -
Antiseeze Question!! Need Answer Quick
By camarostripes96 in forum LT1Replies: 1Last Post: 04-30-2008, 10:39 AM -
Anyone Watching MTV true life-"street racer"?
By z28punk in forum Almost Anything GoesReplies: 32Last Post: 02-01-2007, 12:07 PM -
Crane 1.8:1 "Quick Lift" rocker arms
By u69038 in forum Internal EngineReplies: 3Last Post: 04-21-2006, 11:30 AM
