Results 1 to 20 of 20
11-13-2007, 08:25 PM #1
When Is An Aluminum Girdle Necessary?
Title sounds like an Oprah episode, eh? j/k
I've got the bug and am going to start modding my 2001 SS.
I know these cars have a weak rear end so I was thinking that the aluminum girdle should be my first mod, but I don't know if I need it.
My car is an auto, 3.23 gears, CAI, SLP lid and Loudmouth exhaust.
It is a street car only. No drag strips, no drag radials, no stalling up the torque converter (unless a Mustang is in the next lane, heh heh, uh, theoretically speaking of course).
Am I OK?
Or should I order it now?
My first mod is going to be LT headers because my LM exhaust has an annoying resonance at around 2k rpms and I've read that headers can remove that.
Will the headers spell the end of my axle without a girdle?
Thanks for any info!
11-13-2007, 08:49 PM #2Just me
- Nov 2006
- Broken Arrow, OK
Headers should not spell the end of your rear end. Auto(A4) trannies are much more forgiving on the rear end than manual(M6) trannies.
Its not uncommon for M6 LS1 combos with stock power levels and slicks to blow rear ends. You can add several mods to an A4 LS1 before it usually breaks a rear end though.
11-15-2007, 09:20 PM #3
Waste of money. Skip it. A4 with no drag strip time will be fine.
11-16-2007, 03:19 PM #4This Light Dinner Is Over
- Jan 2007
- Hamburg, Germany
Silver- 1998 Camaro Z28 A4
i have one, if you have gear noise, it will quiet down a lot. also, they are supposed to keep the temperature down, good if you drive fast over longer distances (my freeway speed is usually 100+). i also like the fact that it has a drain plug.
11-16-2007, 05:27 PM #5
11-16-2007, 09:57 PM #6
What exactly is an aluminum girdle?
11-16-2007, 10:36 PM #7
11-16-2007, 11:35 PM #8
what's a preloaded bearing cap? how does it work? jw
11-17-2007, 12:32 PM #9
11-17-2007, 01:03 PM #10
11-17-2007, 08:43 PM #11
Could it actually prevent ur rear end from braking?
11-17-2007, 09:50 PM #12
Directly prevent it from breaking?? Probably not. But could it help by keeping the bearing caps from flexing and therefore preventing gear whine and damage to the ring/pinion which could lead to rear end failure?? Definitely. And for that reason, I think its a good investment. Not to mention the drain plug is also very useful.
11-17-2007, 10:25 PM #13
Doesnt sound like a bad investment
11-17-2007, 10:50 PM #14
I don't think it helps keep the rear from breaking, just looks cool and the drain plug is a plus.
11-18-2007, 03:24 AM #15
11-18-2007, 01:48 PM #16
11-18-2007, 02:54 PM #17
I have one. Definatly doesn't quiet the rear down, but it does keep the rear end oil cooler and has a drain plug. Plus any little bit of strenghtening it adds can't hurt. Also if your getting long tubes to get rid of your loudmouths drone you are going to be sorry. With long tubes you will want to throw the LM in a river.
11-19-2007, 06:34 AM #18
They just put pressure on the center section to keep it from shifting backwards. Flex in the rear will break it, so it's here to limit it.
11-26-2007, 01:15 PM #19
ah i just need to go to howstuffworks.com or somethin cuz this is all spanish to me... differential carrier? damn.. i hate when i dont know stuff
11-26-2007, 01:19 PM #202 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
REAR end girdle
By tonyjnjz in forum DrivetrainReplies: 12Last Post: 09-01-2008, 08:53 AM -
T/A rear end girdle?
By Z28LS1 in forum DrivetrainReplies: 4Last Post: 04-14-2007, 01:49 PM -
rear end girdle
By silverz28camaro in forum DrivetrainReplies: 9Last Post: 03-13-2007, 02:11 PM -
Rear end girdle...
By Mr. Luos in forum DrivetrainReplies: 5Last Post: 05-23-2006, 03:19 PM -
WTB 3.73's, and girdle if possible!!
By Hark_Z in forum Parts Wanted / TradeReplies: 0Last Post: 11-24-2005, 10:25 AM
lol
