Thread: Question about strange rear??
11-13-2007, 06:49 PM #1
- Oct 2007
- Glen Burnie,MD
Black- 2000 SS,M6
I bought a camaro ss. about 2 months ago and the owner had a strange 12 bolt rear. already assembled. it was installed by F-body central. but I have a question about gear whine. I hear it most at 50-70mph it has 4.10 gears. and have talked to some people and they say its normal some say the rear has to set-up again. I just need some more input. the rear has about 15K miles on it. is it the gears? bearings? also the axle seals are leaking. the car is eqipped with C-clip eliminators. Sodo I need to buy new axle seals and reseal the eliminators. thanks in advance
11-14-2007, 06:29 AM #2
- Jun 2007
- Lathrop, Missouri
Seems like a lot of guys with a 12 bolt's and 6 speed's develop gear whine. Also if they are richmond gears they will whine as well.
11-14-2007, 05:40 PM #3
- Oct 2007
- Glen Burnie,MD
Black- 2000 SS,M6
thanks Boss
11-15-2007, 03:13 PM #4
ive always wondered the whining is due to the wrong weight of rear end oil
11-16-2007, 05:56 AM #5
11-23-2007, 05:52 PM #6
My Strange 12 bolt with 4:10s screams. I wouldn't worry about it. I'd fix the leaky seals tho. I'm sure Jason at FBC will take care of it for you.
12-05-2007, 07:33 AM #7
- May 2007
- Seattle
Purple- 1998 T/A convertable
The whine comes from one tooth slipping off and pinging the next tooth. The helical cut gears area supposed to eliminate this. Its the only reason, straight cut ones are a hair more efficient, but many don't like that whine. Most race cars whine because they're performance only. Having the wrong lube usually just burns out the diff plates, but the higher the gear, the higher the heat, the more damage to oil and it dosent work right. most street apps don't need coolers, but if you have 6:10's or something like that (god knows why) you really need a rear cooler.
STRANGE S60 Rear?????
By DaddysZ28 in forum DrivetrainReplies: 12Last Post: 09-13-2010, 04:35 PM -
New Strange S60 rear
By Fastcar in forum DrivetrainReplies: 2Last Post: 06-22-2009, 09:22 PM -
Strange S60 rear end
By Kavslayer in forum DrivetrainReplies: 5Last Post: 05-31-2007, 03:12 PM -
strange s60 rear end questions
By 92ZZ3RS in forum DrivetrainReplies: 14Last Post: 07-19-2006, 01:48 PM -
Strange Rear end
By Kavslayer in forum DrivetrainReplies: 3Last Post: 01-17-2006, 10:39 AM
