Results 1 to 20 of 25
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Angry Damn Spark Plug Wires!
    Alright, I'm in the process of changing my plugs and wires on my 2000 SS. The driver side went smooth and all in all took me about half an hour. Now for the dreaded passenger side. First off it doesn't help that I have ginormous hands. I started with plug 8 since it seems to be the most difficult, after about 30 min of pulling and tugging the stock wire came off of the plug and the rest was cakewalk. (By the way I accomplished this from under the car, I had a clear path to 8 with nothing in the way.) My problem is plugs 2,4 and 6. The damn plug wires DO NOT want to come off. I've tried everything, pulling, twisting, everything! I even lifted the coil packs and removed the air tube connected to the exhaust. What are some suggestions you guys would have for stubborn spark plug wires? Any help would be greatly appreciated.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    I stick a long screwdriver in there behind teh boot and pull it out, it' takes some force but it should pop off of there. I always remove the coil rail completely, and pulled out the AIR tube when I had AIR. Please don't get pissed and pull on the wire itself
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    I heard a few guys on here say the stockers were the hardest to pull off? I guess I'm in that same boat?... How long a screw driver would you say I need? I'll give anything a try now. Thanks.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Eh, mine is probably 12-14 inches long. Just something to push on teh boot with
    Arizona
    They are much easier to get off the second time if you install them with a little dielectric grease.
    Member 99transamC/FIA's Avatar
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    spark plug wire pliers.
    md
    00 ws6
    if youve got headers, plug 8 is a cinch........ from under the car
    Ricekiller z28punk's Avatar
    Maple Grove, MN
    2002 Camaro Z28
    I usually use a small pry bar. u could get a spark plug boot pliers too.
    Feb 2007
    austin
    Black/Black
    '00 Firebird WS6 T/A
    i just used my robogrips
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    I got them finally! Took forever... I made sure to put boot stuff on for next time. It should be way easier then. I had to put a pipe over one of my wrenches to get #6, just couldn't get enough leverage. Other than that everything went smooth. Started her up and she purrs, there's a very noticible change in throttle response.
    RAN MAN CAN RANSTRANSAM's Avatar
    MS.
    SUNSET ORANGE
    2001 TRANSAM
    i have a01 transam , what is the best sparkplug to use for performance??
    Feb 2007
    austin
    Black/Black
    NGK TR-55's are big if you're NA and TR-6's if you have n2o or FI.
    MS.
    SUNSET ORANGE
    2001 TRANSAM
    Quote Originally Posted by richard head View Post
    what
    What the Hell! SuperSport's Avatar
    Orlando, FL
    go with NGK TR-55 plugs
    Member Empatho's Avatar
    San Diego
    02 Z28
    Quote Originally Posted by SuperSport View Post
    +2 if you dont know what n2o or FI is then it means you dont have it so go with the TR-55
    2002 Z28 Auto (3.23 gears)
    Mods
    Lid, UD pulley, Shift Kit, 160 Thermo, Y-pipe, Panhard, TB bypass, Bellow, K&N, Strut Brace, Flowmaster, weight reduction.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    When i was chaning mine, i got so mad i pulled a wire so hard, it broke into 2 peaces. The part of the wire than goes on the coilpack came off but the other end that is connected to the plug was still stuck. I also broke my ECT sensor and it was not fun. My car ran like shit for a week and my friends ford explorer beat me in a race LOL! I decided to shell out the extra $ and get TR55-IX plugs. They are iridium and tend to last longer. I dont wanna keep changing them or have to worry about them cuz we all know hoe much fun it is to change the plugs on our cars.
    Arizona
    Really? I always thought the plugs are easy to change on the LS1 F-body. I have never had problems with mine.
    Driver side is a breeze,,,,first 3 on passenger side are also easy,,,then the last one is done from underneath the car.
    I changed them with manifolds and cats in place,,,,but since I have gone to long tube headers and no cats,,,,I find the plugs even easier to change now.
    I find my wifes LT1 more difficult than my LS1,,,,and if you really want busted knuckles,,,,my 454 chevelle,,,with aftermarket aluminum heads that have the exhaust ports raised 1/2 inch,,,so the headers are higher up,,,and they are 2 inch diameter hooker super comps on top of that,,,and the car has factory air conditioning as well. It's a real joy. I have several modified sockets to get the job done.
    MS.
    SUNSET ORANGE
    2001 TRANSAM
    Quote Originally Posted by Empatho View Post
    whats your et time
    San Diego
    02 Z28
    havent taken my car to the track but I really whant to
    MS.
    SUNSET ORANGE
    2001 TRANSAM
    MINE RUNS A 13.222 MODS ARE AIR LID,K&N,FLOWMASTER MUFFLER,THROTTLE BODY BYPASS,AND THINKING ABOUT DOING THROTTLE BODY PORTING BUT NOT SURE IF THAT WOULD MAKE ANY DIFFERENCE
  1. Spark Plug Wires on E-Bay
    By Z34LS1 in forum General Help
    Last Post: 07-11-2012, 05:58 PM
  2. Spark Plug Wires
    By muteki in forum External Engine
    Last Post: 05-20-2008, 07:19 PM
  3. Spark Plug Wires
    By 6speedTAthistime in forum General Help
    Last Post: 11-30-2007, 05:20 AM
