Results 1 to 15 of 15
    Member ApexVIII's Avatar
    Modesto, CA
    1998 Camaro Z28
    Question i know, i know but Hot cam VS CheaTR??
    ok i did some searching but i am a real noob when it comes to LS1 cams,
    i have LT,s but i want a cam that will pass the sniffer, would you guys recommend the GM Hot Cam or the CheaTR cam? or is there a better cam that i can use with stock ls1 heads for now?(will be putting in ned valve springs)
    later i want to get a CNC LS6 head, but not for a while.
    M6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    the biggest you can go in cali and pass is the 224/224. thats the cam i suggest and have in my car
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Modesto, CA
    1998 Camaro Z28
    Quote Originally Posted by nhraformula View Post
    sorry i dont really know much about cam set ups, what cams are 224/224? is either of them one?
    Dec 2002
    n/w chicago
    the 224/224 is a single pattern cam.
    just about all ls1 tuners ell that cam/grind
    Member 180ls1's Avatar
    San Diego (Poway)
    1998 Firebird Formula WS6
    Quote Originally Posted by ApexVIII View Post
    224 intake and 224 exhaust lift
    Modesto, CA
    1998 Camaro Z28
    is a 224 224 larger then th GM hot cam or CheaTR cam? which one will make more poweR?
    Thanks
    Derek
    Dec 2002
    n/w chicago
    the 224 is larger and makes more power than both
    Modesto, CA
    1998 Camaro Z28
    sweet! thats what ill be going with then!
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    Quote Originally Posted by 180ls1 View Post
    correction, he isn't talking about lift, 224 is the duration of both the intake and exhaust. lift will be somewhere around the low to mid .500's.
    Baltimore, MD
    98 Z28
    I would go with the hotcam for a daily driver, but that's just me.
    Fuquay-Varina,NC
    Light pewter metallic
    1999 Pontiac Trans Am
    I don't know about sniffers, but the Hotcam kit is great for the money.
    Baltimore, MD
    98 Z28
    Quote Originally Posted by Redlinez View Post
    +1...don't listen to the naysayers. I got my hotcam and picked up 31hp..so much for the hotcam is just noise and doesn't produce any power. There's a lot of ignorance here about cams.
    Dec 2002
    n/w chicago
    Quote Originally Posted by Calico View Post
    most people dont though.
    there are better cams out there that make better all around power and are still very driveable.
    Modesto, CA
    1998 Camaro Z28
    i think i decied on the TSP 1.56 5.3 head and cam kit with the 224R cam
    Fuquay-Varina,NC
    I've seen a ton of hotcam cars put down 380-400 rwhp with all supporting bolt ons. I think cams are way over hyped, and I'm probably just as guilty as the next guy for falling for big cam numbers. It's hard to really compare what cams do what if you don't have a car that is consistently hooking and being driven well with the only difference being a cam change. Hardly anyone tells you everything they've done to their car. Heck, most only post rwhp because their et doesn't even close to being impressive.
  1. Help: Shorty header Street cam besides CheaTR cam?
    By Blue28 in forum Internal Engine
    Last Post: 12-04-2009, 04:45 PM
  2. cheatr cam
    By disc0monkey in forum Parts Wanted / Trade
    Last Post: 01-10-2009, 06:42 PM
  3. Cheatr LS2
    By DV327 in forum Internal Engine
    Last Post: 12-18-2007, 08:19 AM
  4. cheatr package time??
    By Scott5586 in forum Camaro / SS
    Last Post: 06-18-2007, 01:13 PM
  5. Cheatr Cam
    By 1959ls1 in forum Internal Engine
    Last Post: 10-01-2006, 01:37 PM
