Results 1 to 3 of 3
11-02-2007, 06:51 PM #1Junior Member
- Jan 2006
- garland
burgundy, black cherry- 1995 impala ss
Rear End Question ---- Need Help Please!
I have the opportunity to buy a posi rear end with disc brakes that come from a '89 camaro and another from a '96 camaro. Both are z28 rear ends. My question is..... How wide are these rear ends? Im building a 69 chevy short bed in which im currently converting it to a disc rear end and instead of getting the conversion kit it would be a whole lot easier to swap rear ends.
Another question is..... What bolt pattern are these rear ends? I was told that they are 5x5 but I thought camaros came with 5x4.75
Someone please fill me in at [email protected] Thanks so much!
11-07-2007, 06:12 PM #2Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
I don't think I would put either one in such a heavy vehicle. They have a small ring gear and are too weak. I've seen'em blow up in a small block S-10 before.
11-09-2007, 10:23 AM #3Junior Member
- May 2007
- Seattle
Purple- 1998 T/A convertable
Camaros should be 5x4.75. How much power are you making? I'd go with a 12 bolt if you can find one at a decent price. many trucks used Dana's & 12 bolts. I have a stock 12 bolt in my 70 Formula and it has taken quite a beating. If you're keeping the leafs, you'll need new perchs on them anyway. If it is a little more narrow, you just use bigger tires
try to keep the same offset with them as bearings can burn up.
help! rear end question!
By 1999transam in forum DrivetrainReplies: 18Last Post: 09-02-2012, 04:44 AM -
another rear end question
By badazta in forum DrivetrainReplies: 1Last Post: 03-07-2011, 08:53 PM -
Question: Rear end
By Nosws6 in forum Suspension and HandlingReplies: 8Last Post: 03-11-2008, 10:44 AM -
Rear end question??
By Camaroride32 in forum DrivetrainReplies: 22Last Post: 01-17-2008, 05:17 PM -
99 SS rear end question
By mdbro in forum Camaro / SSReplies: 4Last Post: 04-23-2006, 08:05 PM
