Results 1 to 10 of 10
    Colorado
    2002 Camaro Z28
    Mid to late 90's Sliverado, Tahoe, Suburban owners please help!
    I have a 1997 tahoe with the 5.7 liter Vortec V8. My oil pressure guage was not working so I took it in to get it fixed. The guage is part of the whole cluster so I had tobuy a whole new instrument cluster for $380.00. Before I replaced it my charging guage read 14 volts all the time now it is barley reading 10 volts. What is your reading and is this exceptable rang for a new guage?
    My new oil pressure guage reads 20psi hot idle andabout 40 crusing on the highway. Is this a good and how close is it to your read outs?
    MY engine temp guage reads 3/4th the way to 210 degrees. Seems low to me but it reads the exact same temp as the old cluster did so maybe it is right.
    Truck has 130,000 total miles all original and runs GREAT!
    Here are several pictures of the new cluster read out and all are fully hot engine:
    This is hot idle in park
    Here is a shot hot idle full cluster:
    Here is one driving 25mph:
    Here is one driving 50mph:
    Here is a shot with the RPM's at 2,000 in park to show you readings with out a load:
    Can you guys check your readings and let me know if these readings are close to being one or if they are way off. I'm a little pissed cause I wanted the new guages to read right on and I have a feeling that they are off a bit especially the volt meter.
    The shop did install a cellinoid to prevent my camper trailer from draining mytrucks battery. It seperates the 2. I'm wonderig if this may have something to do with the charging guage reading so low. I had Napa check my charginf system and all checked out good but the dam guage is still reading low. Here is a few pictures of that cellinoid that prevents my trailer from draining my truck battrey. Can you tell if it is wired up right?
    Thank you for any input!!!!!
    I keel you! Blitzed's Avatar
    Titus,AL
    Black as Wesley Snipes
    09 Mazda 3, 12 Z1000
    First post!!!!!!!
    Senior Member whitelightnin99's Avatar
    SC
    go to www.fullsizechevy.com for help
    Lumpia eatin' fool Vee 6's Avatar
    San Diego, CA
    Black, of course!!
    87 Buick Grand National
    I have a 98 Tahoe, w/ Vortec 350. It has 181,000 miles. Your gauge readings look like normal, except the volts. Mine is near 14 volts!
    My hot oil pressure at idle is about 25 psi and my temp at all speeds is the same as your first pic.
    Keep in mind factory gages aren't exactly the most accurate either...but I would be a bit concerned about the volts.
    87 Buick Grand National - 10.79 @ 123.24, 1.57 60'
    95 Z28 - K&N filter, faded black paint, slow
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Might want to check your alternator
    Colorado
    2002 Camaro Z28
    Thanks guys! That helps a bit! I'll recheck the charging system. Good toknow the oil pressure is with in specs.
    Lt1/m6 driver :P Toyota h8r's Avatar
    Feb 2007
    toledo, ohio
    327-TPI/A4
    1992 Trans am
    when was the last time the blower motor has been changed? Im not trying to sound like a dumbass but on my dads 96 GMC z71 everything matched your gauges PERFECTLY! At one point during a trip i was driving and noticed volts meter at 9 volts! So we pull over and check battery and it reads 12.9.....then we noticed that blower motor was off......we turned switch back on and it did it again! So we replaced the blower motor and all was good after that.
    But your oil pressure is the same as ours......been that way for last 11 years lol!
    and the truck is at 150k
    member HASTINGSRJ's Avatar
    Jan 2001
    Franklin, Mass
    00 SS Vert#0540/ 14 GMC
    oil pressure and temp looks right not sure about the volts though. I know that my oil pressure guage moves a lot though, when I stop and start going again. I have around 103k on my truck and it runs great.
    Black 00 SS M6, vert, #0540 408ci
    DD 2014 Sierra All Terrain
    SCPO - Retired joerockhead's Avatar
    Mile High
    BlackCherry
    Bad Ass 67 Camaro / 2010
    When I had my 95 K2500, the Volts always read just a hair over 14.
    But as long as you are charging, you are fine.
    Junior Member aeromachine's Avatar
    phoenix az
    Just curious who took the picture of the dash at 50MPH?
  1. Craig Ferguson Jabs at Bill Mahr, Late Late Show (vid)
    Last Post: 06-06-2013, 08:59 AM
  2. Question: 93 Suburban TPI
    By Hyzell in forum GM Trucks
    Last Post: 02-21-2008, 09:21 AM
  3. Replies: 0
    Last Post: 11-01-2007, 11:47 PM
  4. 2004 Chevrolet Tahoe - DIY 2004 Tahoe
    By Ed Blown Vert in forum Stereo and Electronics
    Last Post: 08-16-2007, 12:50 AM
  5. 605 cid suburban!!!
    By tonyjnjz in forum Almost Anything Goes
    Last Post: 12-07-2006, 08:11 AM
