Results 1 to 14 of 14
    Member BLACKNIGHT03Z06's Avatar
    Georgia
    2002 Z06 Corvette
    Angry Please help ASAP/ Reduced Engine Power
    2002 Z06 in my sig. I had just washed my engine and was headed home not driving very aggressive and no sounds, no pops, no jerks, but the information center starts going crazy with code. Reduced Engine Power / Service Traction Sys / Service Active Handling - Codes:10-PCM P1120 H C(Throttle Position (TP) Sensor 1 circuit), 10-PCM P1220 H C (Throttle Position Sensor 1-2 Correlation), 28-TCS C1278 H (TCS Temporarily Inhibited by PCM), 99-HVAC B0338 H C (Inside Air Temp Sensor Open) I,ve gone through the resets but everything comes back. Any suggestions for how to clear the reduced power and TCS problems? I believe the P1120 & P1220 are a result of the reduced power mode. What the heck is inside air temp sensor open on the HVAC. I noticed the display panel for HVAC has most of the light not on at night. I just bought this car. Any advise besides take it the a dealer would be appreciated. If that's the only thing to do from here I will.
    Thanks.
    02' Z06 EB/EB 4.6K miles, Longtubes, Off-road X, Pypes X-back, Blackwing CAI, Comp. Cam 238/240-.605/.609-112LSA, Comp. Beehive Springs, Comp. Titanium Retainers, Comp. Perf. Push Rods, Comp. Billet Double Roller Timing Chain, Hurst Short Throw, Cray 19"/20" w/ Toyo Proxes4 265/30/19's & 295/30/20's
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    sounds like you got the TPS sensor wet. remove the connector and see if there is water inside of it.
    Georgia
    2002 Z06 Corvette
    Do you know where it is located. Can I reset the reduced power mode if that's the problem?
    Thanks
    Senior Member camarojunky74's Avatar
    corona ca
    white, white and pewter
    Rip99SSA4,74Z28M4,02SSM6
    its located on the side of the throttle body which is at the inlet of the engine, follow the intake too it, not being sarcastic just being clear,
    aslo you may have just wet the pcm or something similar, try disconecting the batter for about 10-20 minutes and hook it back up and drive it your problem may go away, this is of course that you think the engine is dry, maybe pop your hood and let it sit out in the sun for a bit
    Georgia
    2002 Z06 Corvette
    Quote Originally Posted by camarojunky74 View Post
    Thanks man. Will disconecting the battery wipe out my custom tune?
    corona ca
    i figured that you had one since you got a blower and all that, and you will be fine, that tune is written into the computer, basically if you are familiar with computers you just restarting your computer, in a sense. your custom tune was written in the pcm in place of the factory tune so the only way it would go away is by re writing the factory tune
    corona ca
    i hope this clears that up, i am pretty sure it will how long ago did you wet down the engine? ,
    also in the future some simple green and a soft bristled brush will go along way with cleaning the top of the motor and inner fenders, and just a light rinse using some good common sense to keep direct water flow off of electrical connections and or fuse box and pcm
    Georgia
    2002 Z06 Corvette
    I did it last night. I'll keep it dry and use compressed air to blow it out. No more pressure washing for me. Thanks man.
    corona ca
    no prob, dont thank me yet your not outta the woods lol, but i think this will clear things up for you
    NeW YoRk
    2001 ws6
    just sell me the car for say...10 g's? and then u wont have anymore problems haha....na let it sit out like said above u prob just got a connector wet
    corona ca
    come on man all this help i give, lets see some pics of the sick ride, itll make me happy
    Quote Originally Posted by BLACKNIGHT03Z06 View Post
    lesson learned??
    One other thing to keep notice of is your drain on your cowl. The vettes have a history of that drain getting plugged up and water overflows right onto the cars pcm and it'll throw tons of odd codes. Just something to keep an eye on.
    Georgia
    2002 Z06 Corvette
    I'm trying but all my jpegs are too big. I'll try to resize.
    Georgia
    2002 Z06 Corvette
    Question Pictures
    Go to the kill forum and look up my thread titled new top speed in my 02' Z06. I posted pictures at the bottom of page one and it tells me that I have exceeded my allowable attachments when I try to put them here too.
  1. "Your engine power is reduced" display
    By Vexzer in forum Almost Anything Goes
    Last Post: 07-28-2008, 07:03 PM
  2. Help: Reduced Engine Power - C5 Vett
    By Rikki_SeVeN in forum General Help
    Last Post: 03-27-2008, 09:13 PM
  3. Need power steering fluid tank and pulley ASAP!!
    By brad8266 in forum Parts Wanted / Trade
    Last Post: 03-19-2007, 04:25 AM
