Results 1 to 14 of 14
Thread: burnouts
10-29-2007, 04:54 PM #1Junior Member
- Oct 2007
- usa
des- 1998,trans am
burnouts
why wont my car leave 2 black burnout marks? it has the posi traction? is this something i should have looked at?
10-29-2007, 04:57 PM #2down with the lot lizards
- Dec 2006
- Pensacola
Red- 2001 Camaro SS A4
look on your drivers side door at the RPO codes..look for G80..that is positraction, if G80 is not there then you do not have Posi...but im pretty sure you do
10-29-2007, 05:10 PM #3I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
You could have an internal problem with your rear end.
That sounded so wrong haha!
10-29-2007, 05:24 PM #4
10-29-2007, 05:26 PM #5!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
ls1's dont come without posi, do they? im also gonna guess u got someting wrong inside your rearend.
10-29-2007, 06:05 PM #6Junior Member
- Oct 2007
- usa
des- 1998,trans am
it will leave a very light mark on the drivers side,but really black on the passenger side.
10-29-2007, 06:06 PM #7
10-29-2007, 06:10 PM #8Junior Member
- Oct 2007
- usa
des- 1998,trans am
ive jacked the car up and turned the rear wheel and it feels ok, the driveshaft turns
10-29-2007, 06:48 PM #9
gotta love one tire fire
10-29-2007, 06:55 PM #10down with the lot lizards
- Dec 2006
- Pensacola
10-29-2007, 06:55 PM #11
10-30-2007, 09:56 AM #12
It is either an Auburn or a Torsen. The Torsen will lay 2 strips. If it doesn't, it is broken and you will know it.
The Auburns are know to leay one leggers when they are worn out.
10-30-2007, 10:07 AM #13
11-01-2007, 06:33 PM #14
Check the RPO codes. If it is in fact Posi-equipped, change the fluid in the rear end and make sure they put in the friction additive. If that doesnt fix it then you have a problem with the rear end. HTH.....
Bowtie good! Blue oval not so good! Bob in the PRK
Burnouts
By Guerrillakilla13 in forum Almost Anything GoesReplies: 46Last Post: 07-06-2012, 05:41 PM -
wow great burnouts
By Speedy_Gonzales in forum Almost Anything GoesReplies: 15Last Post: 03-23-2008, 06:20 PM -
When doing burnouts?
By william SS in forum Drag RacingReplies: 1Last Post: 05-30-2007, 06:27 PM -
Where are your burnouts?
By illcul8troffcr in forum Almost Anything GoesReplies: 19Last Post: 06-04-2006, 11:00 AM -
burnouts help!?
By adamzbabyz28 in forum Camaro / SSReplies: 3Last Post: 03-14-2006, 11:53 AM
sounds like you got one tire that is outta ink
