Results 1 to 1 of 1
10-29-2007, 01:20 PM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Setting Up Ignition Contact Points - Contact Point Connection
There are myriad products available today designed to replace the mechanical contact points found within a conventional distributor and convert it to electronic operation. While such conversions are quite popular, there remains a large number of vintage Pontiacs occupying today's roads that still contain yesterday's technology, and they require occasional maintenance and eventual component replacement to maintain peak operating condition.
While such tasks seem relatively simple for those familiar with points-type systems, many novice hobbyists are unfamiliar with the characteristics of contact points, and consider the maintenance and replacement a science similar to quantum physics, but nothing is further from the truth. Follow along as we install a fresh set of contact points in a conventional Pontiac distributor, and prepare it for countless miles of trouble-free operation in less than an hour.
Contact Points Basics
The contact points within a conventional distributor transfer electrical current from the coil to the spark plugs, and its action is controlled by a small cam that rotates about the distributor's mainshaft. A magnetic field builds within the coil while the points are closed. The duration that the points remain closed, which is expressed in degrees of rotation, is referred to as "dwell angle." As the points open, the magnetic field collapses, and an intense electrical spark travels the air gap from the spark plug's electrode to its ground strap, igniting the compressed mixture.
As the contact points surface and plastic rub block wear during normal operation, the dwell angle changes. As dwell exceeds its specified range, spark intensity degrades (and spark advance changes), ultimately affecting emissions and performance. Periodic contact point adjustment is required to ensure that dwell angle remains within a specific range to maintain peak engine performance. Once the contact points wear beyond practical adjustment, eventual replacement is required.
Replacing The Contact Points Set
Replacing a distributor's contact points set is very straightforward. It involves nothing more than simply removing the existing assembly and installing a replacement. The required preliminary dwell adjustment that immediately follows, however, can be the most difficult portion of the swap, and that can seemingly lead to an engine without spark.
In years past, some manufacturers pre-adjusted the contact points sets during assembly, and when installed into a distributor, were found to be within a reasonable dwell range for easy engine start-up and final dwell adjustment. Many of today's contact points sets are nowhere near a reasonable dwell range, and oftentimes require physical measurement to ensure quick engine start-up. The accompanying photos show that process in detail.
Conclusion
An argument against contact points has often been required maintenance, but that's largely a non-issue when we consider how sparingly our vintage Pontiacs are driven today. So if you own a Pontiac that was originally equipped with a points-type distributor, and you prefer its mechanical function over an electronic conversion, expect complete contact points set replacement to take about 30 minutes and set you back around $25. After that, a slight amount of periodic preventative maintenance is typically all that's needed for thousands of miles of reliable performance.
Photo Gallery: Setting Up Ignition Contact Points - High Performance Pontiac Magazine
More...
Help: Contact information
By CptMidway in forum Wheels and TiresReplies: 0Last Post: 03-12-2008, 10:55 AM -
Can someone contact me about Va Inspections
By mikeaford in forum Eastern MembersReplies: 0Last Post: 08-31-2007, 10:19 AM -
Contact Us
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 12-09-2006, 07:30 AM
