Results 1 to 14 of 14
    Member JattGunMan's Avatar
    cali
    2000 ss
    255/40/17 Costco said they wont install them on a camaro!!YYYYY
    so I called costco this morining about some 255/40/17 Front tires..for my camaro and they said that they could not install them because it would not hold the cars load and will mess up the speedo!!!But the car came with that size when i got it!!!SO should i buy 275/40/17 instead??? need tires todayyy so plz let me knoww
    Florida
    Oriental Blue
    2001 Trans Am WS.6 M6
    maybe it was because of the speed rating? thats all ive got
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    i dont know how front tires would mess up the speedo since it gets its info from the transmission. maybe i would go somewhere else to get tires. do you have a mavis or sts nearby?
    NA
    if the car came with that size.. look at the label on the inside of the door.. it'll say the size. bring it to them and tell them LOOK, the car is designed for this tire size.. put it on or i'll take my business else where.
    if that fails just throw on 275's. mmm. meaty!
    LS1 land
    17" SS rims come from the factory with 275/40/17 tires and that is what you should put on there. Some retard shop or previous owner must have put the 255's on.
    Pistol Pete '96 Z28SS's Avatar
    Cowboy Country Stillwater, OK
    Bright Rally Red
    1996 Camaro SS
    i would go the 275/40/17 route, give it the rubber it deserves
    cali
    2000 ss
    ah crap!HAHA well in hast i decided to just stick on some more 255's that it had i honestly cant really tell the diff. between the 275 in the back and 255 up front on my car now...maybe because the people at discount tires pumped them up to 36 psi for some reason?(should they be at 36 psi?)I shouldnt of rushed but i was riding on a spair donut and a peeling apart front left!the (lady)at costco said that they can only go up in tire size not down.she said the speedo will be thrown off and of course my tires will both explode causing my car to do a front flip haha jk....THANKS GUYS I WILL DEF..Get THE 275's Next Time THough. man i wish i read this earlier
    LS1 land
    Quote Originally Posted by JattGunMan View Post
    yes, she is correct your speedo could be off, but it would be off very very little. Its not like a gear swap or anything. In the future never listen to anyone who works at a costco, walmart, sams club, goodyear, pep boys etc. - 95% of them don't know a fucking thing about cars, and even less know anything about a muscle car.
    College Station TX
    2000 &2002 Z28
    do u have 16 or 17 in wheels?
    The 16 inch wheels are 255's and the 17's are 275s
    cali
    2000 ss
    there 17's with 255 on them now..i was wondering if they put in to much air pressure for a 255?the psi is at 35
    Feb 2006
    Orange County, NY
    always dirty
    it should probably be somewhere closer to 32. look on the inside of the drivers door for what it should be.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    The tire indicates the amount of air pressure it should have. Check the sidewall. Discount Tire always puts between 32 and 36 in my tires and they should have 51 in the rear and 42 in the front. Different brand of tires. When they're at 32 they look like they're almost flat and the car also feels sloppy on the road.
    NA
    No, you don't want to put the PSI indicated by the tire. That's MAX psi.
    You go by what it says on the door. If you want to get real precise.. you want to look at your tire wear to determine if your tires need more or less air in them.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    not to hijack the thread, but how wide of tire can you put on the stock SS rim? I know some people put 285's on them. can you do 295 or is that a bad idea?
  1. Still wont start after fuel pump install
    By OneFastZ in forum General Help
    Last Post: 08-10-2015, 07:31 AM
  2. Help: HELP camaro wont start :(
    By SSickLS1 in forum Camaro / SS
    Last Post: 03-19-2011, 11:29 AM
  3. 02 camaro cranks wont fire pass key problem?
    By PAT-LS101 in forum General Help
    Last Post: 01-22-2009, 03:54 PM
  4. TCS Wont come back on after cam install help!!
    By NeeD4SpeeD in forum General Help
    Last Post: 03-01-2006, 06:23 PM
  5. wont shift at WOT HELP! after cam install
    By ahowell3 in forum Automatic Transmission
    Last Post: 01-28-2006, 05:47 PM
