Thread: Procharger Install time?
10-25-2007, 03:56 PM #1
For you guys that installed a procharger kit at home, how long did it take you to complete? And also what was the most difficult task? Im getting ready to install a d1-sc kits from EPP........Thanks
10-26-2007, 01:46 AM #2
Took me a couple weekends including the fuel pump. If you got the front mount IC that may add some. I'm not the fasted mechanic either.
10-27-2007, 04:07 PM #3
10-27-2007, 05:43 PM #4
I did mine in 2 weeks lol , i didnt get in a Hurry & I wanted to make 100% for sure everything was Right,i had the Balancer off for the camShaft change & Ended up sticking a Flathead screwdriver in the Back of the Flywheel to torque the Balancer bolt back on to 240 ,I am also running a Novi2k with The LargestIntercooler i have ever seen,It is the ECS kit ,I havent taken any later pics heres one underneath the 00 vette I went ahead & Bought the New Tsp 402 for a Back up
this is the rest of the mods done to the vette Ecs Paxton kit +8 lbs of Boost ,Msd 2350 Bap ,Ecs cam,Comp Lifters,TPIS 1 &3/4 LNG Tbe hdrs,Patriot Stg 2 heads With Gold Dual Vlve springs Good for 650 lift,Hardend Cromoly push rods,Ported Oil PUmp,Z06 intk,3.42 gear,3600 yank cnvrtr,Flt tranny With Transgo Shift kit ,Hardend halfshaft drivers side, Still To come :TSP 402 Aluminum Block , 9 to 1 comp, diamond 15cc ,Scat Rods,Eagle Crank,
10-28-2007, 03:35 AM #5
You have to lock the flywheel some how, when I did the install I still had an M6 trans so I put it in 4th, set the brake, chocked it & put the handle from my floor jack over my flex handle & cranked it as tight as I could which probably did not amount to the 270 degrees after 30 ft lbs as specified. It's been on there a couple years now & no issues.
You need to be real careful with the plastic fuel lines attached to the top of the fuel tank. Lower the tank carefully & don't kink any of the lines. I had to drop the axel too (9inch).
10-31-2007, 06:41 PM #6Junior Member
- Oct 2007
- virginia
dark teodore metallic- 2000 silverado
we installed mine in 8 hours, but it wasn't our first install. and mine is intercooled with meth injection. but trucks are much easier. not fuel tank dropping, it's a inline pump.
11-01-2007, 09:28 PM #7Junior Member
- Dec 2005
- Hendersonville, NC
Black/Black- 1999 FRC
Did mine in a weekend. Friday, Saturday, Sunday. The worst part was pinning the crank, messing with the steering rack, ect. Installing the actual procharger, brackets, piping, intercooler, ect. was a breeze. Just take your time with it.
ProCharger LSX Serpentine Kit Install - LS3 Heat!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-15-2012, 07:20 PM -
anyone have Procharger's Install Manual?
By SVG210 in forum Forced InductionReplies: 2Last Post: 07-02-2010, 05:15 PM -
Procharger install done new issue to deal with
By devil6rr in forum Forced InductionReplies: 11Last Post: 03-16-2009, 05:53 AM
