Results 1 to 20 of 40
    Senior Member kool-aide's Avatar
    Deltona, FL
    Sebring Silver Metalic
    2002 Camaro Z28
    Pics rear quarter flex wrinkles dimples?
    Does any one have pics they would like to share that shows the typical dimples, wrinkles, dents, etc caused by too much body flex without SFCs?
    My car looks pretty clean but would like to see what an f-body looks like that has this kind of damage. I will have to take pics tomorrow when the sun decides to come out.
    thanks
    kool-aide
    Bragg NC
    Met. Sunset Orange
    01 SS
    I dont have any pics on hand but i started to get the Infamous "dimples" on my SS befor i put my Sfc's in. Right above the center of rear wheel area.
    J
    Canada eh
    99 TA
    i have them too, if you get them fixed (dent puller type deal) will they come back? I have sfc's now
    Bragg NC
    Met. Sunset Orange
    01 SS
    Since my Sfc's i havent seen them come back and since then the car has had several upgrades and alot more power to the wheels.
    J
    Marylandistan
    2001 Trans Am (sold)
    I had one once. My paintless dent repair guy took care of it. Got subframes and haven't seen another since.
    Deltona, FL
    2002 Camaro Z28
    well for the third day in a row it is cloudy and rainy. Maybe I will have pics tomorrow. Although from the sounds of it I doubt I have any wrinkles or flex.
    thanks
    kool-aide
    www.eautocad.com
    FL
    1998 Camaro Z28
    I've got both. Its disgusting. But I look at it as a sign of it being fast.
    Junior Member Jeremiah's Avatar
    Jun 2006
    Mustang Ok.
    98 Mecham TA #4 of 14
    It is a common problem with fourth gen F bodys. Even if it is bone stock it will most likely have a few dimples over time.
    Frame rail connectors are a good idea on our cars but they will not cure this problem. A roll cage is probably the only option to brace or help stabilize the rear of the car.
    SFC are a great addition to any F body but they simply do nothing to reinforce the rear of our cars. They connect the front and rear unitized long members deviding the load between them that would other wise be transmitted through the weak floor pan. The rear long member or unitized frame rail is a two piece rail with a "very" weak point "crush zone" just behind the rear seat or cabin erea. This was designed into our cars intentionally to lessen the shock to the passengers in the event of a rear collision. This weak erea or crush zone acts as a hinge and allows the rear of the body to flex just enough that we get the dimples in the quarter panels. The quarter panels are a structural component on our cars and they do get a lot of stress applied to them. I also have seen countless stock unmodified cars with the dimples and I feel it has far more to do with the rough roads or driving habbits than the torque output of the engine tweaking them. I have cut these cars appart and pieced them back together enough times that I know the inner structure of them like the back of my hand.
    For this reason I also warn people against cutting slots in the wheel well lip to aid in rolling it for larger tires. Every slot or cut you make you add a stress riser to envite more dimples along with rust.
    The unitized construction of the fourth gen F-bodys is very structurally stabil with the one exeption being the crush zone in the rear.
    Those of you that still have the spare tire, sub boxes/amps ect. in the rear of your car are only placing more stress on the rear. The over hang on the rear of our cars is substantial, this along with the coil springs being right in the middle of the weak zone only make the problem worse.
    Deltona, FL
    2002 Camaro Z28
    that's a mouth full, thanks.
    Well I just installed my draw tite hitch. I guess I should expect wrinkles in the rear soon, cuz i plan on pulling my son's soap box derby car on a small trailer. I got tired of cramming it in the back.
    Feb 2007
    Pa
    99 TA
    Mine got the dimples after i left it at the dealer for a few days to get the rear fixed.I guess thats why i put the hidden throttle stop under the carpet and a hidden extra switch to turn off the traction control.
    www.eautocad.com
    FL
    1998 Camaro Z28
    is that for teenagers or self control? LOL good idea!
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Quote Originally Posted by Jeremiah View Post
    So, for those of us that have some heavy "extras" in the rear, what do you suggest we do to strengthen the weak zone?
    Deltona, FL
    2002 Camaro Z28
    good question, any one have any ideas, besides my two obvious, SFCs and Roll Cage?
    d
    2002 z28
    i have some weird dents on both sides. thought were door dings but there identical locations. . ill post up pics soon as .
    maybe thats what you guys are talking about
    Deltona, FL
    2002 Camaro Z28
    i think so, that's why i asked if any one could share pics. I looked at a few f-bodies before settling on the one i have. Non had anything I would have considered moure than a parking lot ding. But maybe those "parking lot" dings are really the stress wrinkles?
    Maybe Noel will leave some sunshine long enough for me to take pics
    Parma Heights, Ohio
    SOM
    99 Trans Am
    I have them in the quarter panels of my car. The guy before me drove the car pretty hard so they arent from me but they're there. Ill try and get some pictures in the next few days.
    Deltona, FL
    2002 Camaro Z28
    i forgot to get the camera out today. we had a bief spot of sunny, no thanks to Noel.
    I noticed below my t-top black panel in the rear quarter the slightest little something in the body. To me it looks like a small wrinkle. I think the only way i can capture it with the camera is for a real good sunny day to cast shadows or highlight the uneven metal.
    but they are oh so small and hard to notice. I would love to see some that are eye catchers.
    Senior Member 35thAnniZ28's Avatar
    eating bulldog
    son of biscuit
    sooo....where are the pics?
    Deltona, FL
    2002 Camaro Z28
    dunno, i guess no one has pics.
    I have been plagued by seattle style weather since Noel. I can't get a good sunny day to safe my life.
    Berkeley, CA
    2000 Camaro SS #3574 A4
    I saw a thread well over a year ago on here with pics. I think it is in the suspension section
  1. '99-'02 TA DS Rear Quarter Panel (SoCal) - $40
    By clovenhooves in forum Parts For Sale / Trade
    Last Post: 05-04-2010, 07:45 PM
  2. Dent in rear quarter...
    By Mad Bull in forum Appearance Section
    Last Post: 03-14-2010, 05:30 PM
  3. Question: Do you have multiple dents in rear quarter panel?
    By allbaugh_04 in forum Appearance Section
    Last Post: 09-08-2008, 07:11 PM
  4. Flex creases on the passenger quarter panel
    By stimpster in forum Suspension and Handling
    Last Post: 07-31-2007, 10:55 AM
  5. Welding on a new rear quarter panel?
    By King Tut in forum Appearance Section
    Last Post: 10-02-2005, 05:57 PM
