Thread: what size rims and offset
10-25-2007, 02:09 PM #1Junior Member
- Sep 2007
- durham,nc
i have ask this a few times but people keep sending me to the faq and it gives me the size but the front and back has differnt size and offset,this is what i need to know i have a 99 ta looks like ill be putting 17's or 19's on there ,but i would like to have the same size wheels and offset on all 4 corners and i if i do this will the wheels stick out even all the way around ,meaning if i get the same all the way around will the back or front stick further then the other
thanks for any help
ronnie
10-26-2007, 11:36 AM #2Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Not sure if this will totally answer your question, but the front and rear track of these cars are different. I beleive the front track is like a half inch or so wider than the rear, this has no effect on rims. Depending on the wheel width you will need around a 35-55mm offset.
Examples
The factory 17x9 wheels have a 50mm offset
the factory 16x8 wheels have a 56mm offsetCraig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
10-26-2007, 12:22 PM #3Junior Member
- Sep 2007
- durham,nc
thanks thats about what i needed so it sounds like if i put the same size rims and offset the front wheels will stick out about .5" further then the back
10-27-2007, 03:52 AM #4
Help: what offset rims do I buy
By ws6shine in forum Wheels and TiresReplies: 2Last Post: 11-02-2014, 02:30 PM -
Offset on rims from a 2000 C5
By LOCKDOWN in forum Wheels and TiresReplies: 9Last Post: 05-14-2008, 08:40 AM -
whats size rims?and offset
By raw122 in forum Wheels and TiresReplies: 1Last Post: 10-04-2007, 08:39 PM -
offset and rim size question
By Casper1 in forum Wheels and TiresReplies: 6Last Post: 06-15-2007, 09:49 AM -
2000 Z28, What offset + tire size for a 17x9? Is 35mm ok?
By ShadowHawk in forum Wheels and TiresReplies: 6Last Post: 05-31-2007, 09:21 AM
