    Member Castle's Avatar
    Orange County, California
    Midnight Blue
    1998 Camaro Z28 A4
    Really don't want Spacers...
    C5/Z06 295/35/18's in the rear on Toyo Proxes.
    I have read other people here have this set up as well & I am trying so hard to not resort to spacers.
    I cannot seem to find a local shop that will do any fabrication work to the inner well, such as the BFH mod/grinding bumpstops/etc & have no experience on this myself.
    Does anyone have any ideas/suggestions before I resort to spacers?
    Thanks!
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    why dont you want spacers?? there honestly not a big deal
    Midnight Blue
    1998 Camaro Z28 A4
    (Keep in mind I have zero spacer knowledge = total spacer noob)
    A couple things I have heard:
    - Some tracks, if not most, will not allow you to run w/spacers...
    - There is a good chance your wheels can come loose or separated...
    99 SS
    Quote Originally Posted by Castle View Post
    um, i run spacers on my trans am, and my wheels have never came loose or seperated, if that is an issue with how short the studs are then you can buy longer studs, not sure about the spacer at the track thing, most tracks dont even do a through teching anyways so thats irrevelent.
    if that is the case get some stock rims and put some slicks on for when you do go to the track.
    99 SS
    but i run the same size rim that you do on the rear, and with the stock rearend there was some BFH needed in the fender wells, they did not need a spacer with the stock rearend, but when i put in the 9" I needed the spacers for some reason???
    Midnight Blue
    1998 Camaro Z28 A4
    I have no excuse, this is too true.
    So what all would I need to order?
    Jegs seems to have a nice selection of spacers & unbeatable shipping...
    I would guestimate I need 1/2" spacer for each rear, but you mentioned longer studs also right?
    Does this mean bye bye locking lugs?
    99 SS
    not sure, but i took all my locking lugs off cause there a pain in the ass to get off.
    if i can remember I used a 1/4 spacer, are you tires rubbing already??
    Midnight Blue
    1998 Camaro Z28 A4
    The only time I actually hear the rubbing is on driveways, burn-outs & sharp turns.
    After looking up inside the rear wells after a month of driving on them, it looks like the bumpstops are so close to the inner rim,
    that they are touching. If you run your finger along the far inside of the rear tires, your finger stops due to no clearance near the frame.
    There you can see the rub marks down to the metal. The right rear rim seems scraped from the bumpstop, so they must be hitting.
    I would think at least a 1/2" spacer is needed to pull the wheel away from the inner wall. I also need to make sure there is clearance
    for my Eibach-Pro Kit to allow the 1.3-1.5" room for lowering.
  1. 06 gto spacers
    By American Revolution in forum GTO
    Last Post: 01-26-2010, 05:08 AM
  2. Question: Will I Need Spacers?
    By Tickwomp in forum Wheels and Tires
    Last Post: 12-13-2008, 08:55 AM
  3. Spacers?
    By sk8ters501 in forum Wheels and Tires
    Last Post: 02-28-2008, 09:10 PM
  4. Spacers
    By Castle in forum General Help
    Last Post: 10-14-2007, 09:20 PM
  5. spacers
    By kyemt in forum Wheels and Tires
    Last Post: 07-03-2007, 06:56 AM
