Results 1 to 10 of 10
Thread: shift boot
10-23-2007, 09:48 AM #1Member
- Jun 2007
- Florida
Oriental Blue- 2001 Trans Am WS.6 M6
shift boot
hey just wondering if anybody has any suggestions or tips/tricks on how to keep the shifter boot up close to the shift knob, mine is continuously sagging down, i just got a new 01 ws6 since my 2000 T/A is gone
thanks for any info and comments
10-23-2007, 10:34 AM #2Detailing + Design
- Pittsburgh, PA
mine shows a little leg, too:
Custom Car Emblems from third_shift|studios
jaison tortorea
10-23-2007, 10:35 AM #3
they all slide down a little....how much is it sagging?
10-23-2007, 11:18 AM #4Member
- Jun 2007
- Florida
seems to be about an inch, i can stick it back up but it just slides down again, every now and then i see a pic of a T/A with the gap completely closed and it looks way cleaner than mine
10-24-2007, 09:24 AM #5
My only recommendation is to get a shorter shifter rod.
Trust me.
I stuck a strap clamp under the boot on the rod to hold it up and it worked fine, but whenever shifting to 1-3-6 it would pop the boot off at the base. So I said screw it and took it off.
10-25-2007, 07:21 PM #6Member
- Jun 2007
- Florida
well i thought about that, however this one has the factory husrst shifter....for some reason i just dont want to change it...since its a factory option i guess....
10-25-2007, 07:31 PM #7
I'd recommend just getting a short throw and perhaps sticking a mild adhesive on the top of the boot when you're reassembling everything if you think it'll sag.
10-26-2007, 04:53 AM #8
get short shift stick my t/a also has a stock husrt shifter and i dint like how tall it was nor the rubber bushing that helps bend ur 3/4 shift fork. or u can get a diffrent ball that drops it down some.
10-26-2007, 09:59 AM #9
I like the height of mine, but not how sloppy it was with the rubber bushing. So I welded it all together. Filled in the gab between the rod and the retaining washer and then built it up from there for strength. Smoothed it out and painted it and it is a lot firmer than before. Great "somewhat" free mod in my opinion.
10-26-2007, 10:25 AM #10Impwnded
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
I've been pulling mine down thinking it looked cooler..
Shift Boot
By johnfin in forum GTOReplies: 2Last Post: 06-07-2013, 04:49 AM -
Question: shift boot mod
By fbodyNATION in forum Appearance SectionReplies: 2Last Post: 05-31-2011, 09:23 PM -
Automatic Shift boot and new shift handle
By stew215 in forum Appearance SectionReplies: 21Last Post: 04-21-2011, 02:04 PM -
Shift Boot
By AFASTYZFR1 in forum Parts For Sale / TradeReplies: 0Last Post: 05-29-2009, 04:21 AM -
WTB: OEM T56 Shift boot
By ctnative in forum Parts Wanted / TradeReplies: 2Last Post: 09-01-2008, 04:07 AM
