Results 1 to 20 of 20
Thread: Back from the track. . . WTF?
10-20-2007, 06:53 AM #1
I went to the track last night for the 1st time ever to run my car. My first pass I was just scared shitless, the tires broke loose hard so I let off the gas about 1/8 way down the track. It ran a 16.1
Second run. I laid on it pretty hard off the line. Again the car broke way loose so I let it go just a bit and ran a 14.6
3rd run. I said fuck it and floored it all the way through the track. I burned my tires more than half way down the track and ran a 17.1 < Gay
My car is a 1998 z28 with 70k. Runs like new, only upgrades are a MagnaFlow cat back and a complete SLP intake(ram duct, lid and bellows). My tires are garbage, 245 45 17 on SS wheels. They are generics with a bit of rot but still show good tread. The car also has 2.73 gears.
How can I improve this time? I know the tires are at fault a lot. . . But is there anything else? There were plenty of F-Bodies there and all ran 13's +
10-20-2007, 07:05 AM #2
m6 or a4? the only track around me is a 1/8 mile track, i ran 8.55, stock, but i had DR's 275/40r17, sounds like thats what you need
10-20-2007, 07:35 AM #3
re
I am guessing a4 . I have had a a4 and m6. The m6 requires alot more practice to be able to launch . You have to find your cars limits on traction and live on that edge if you want fast times. You should definately be in the 13's.
10-20-2007, 07:42 AM #4
10-20-2007, 08:30 AM #5
10-20-2007, 09:06 AM #6
what was your MPH?? and you need to learn how to launch it and peddle it out of the hole without the tires spinning. and what was your 60' times?
10-20-2007, 10:39 AM #7
1st run: R/T 1.4 (I am brain dead)
60' 2.642
1/8 10.431
1/4 16.16
@75.04mph
2nd run
r/t 1.199
60' 2.484
1/8 9.579
1/4 14.603 @90mph
3rd run
r/t 1.061
60' 2.975
1/8 12.201
1/4 17.531
@ 95.36 mph < how is this possible?
10-20-2007, 10:44 AM #8
id just try a bigger burnout...
spin them till u get some good smoke...
10-20-2007, 10:47 AM #9
10-20-2007, 11:09 AM #10
Another guy at the track just lit up his street tires. Then ran, he ran a 13.8
I just don't realy wan't to roast my tires.
I thought about just getting some slicks, but I am not in the mood to kill my axle.
10-20-2007, 11:25 AM #11Slow'er'Ass
- Thornton, CO
It is up to you if you want to burn up your tires for no reason.
Also don't use the waterbox with street tires. All you end up doing is taking water with you to the starting line. Makes your launch harder, along with the guy behind you.
A street tire isn't designed the be hot as they aren't pure rubber like a slick/DR.
I cooked some older street tires off my car, as I rolled away from the burnout I put my car in 3rd gear and got on the gas. Went sideways at 60MPH without using the clutch.
Also...MT ET radials only like being warmed for 4-5 seconds. And those are damn near a slick.2008 Trailblazer SS
Lowered, HID's, tinted.
10-20-2007, 12:25 PM #12
10-24-2007, 02:41 PM #13
Yeah, definitely work on that launch. I ran a 1.768 60' on Nittos... with a best time of 12.04... and that was missing 4th and dropping 9mph off my trap speed... I am sure I could have hit 11.9xx
Maybe next time.| '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
10-24-2007, 03:49 PM #14
10-24-2007, 05:15 PM #15
pedal it like you've never pedaled before... try to get that 60ft down under 2 secs... and keep it straight down the track...and you should hit the 13's
11-15-2007, 03:13 PM #16Member
- Oct 2006
- Springfield
Silver- 2004 SVT Cobra
Trap speeds and passing times arent always relevant. You could run a 20 second quarter mile and still trap over 100 MPH. A hard launch with good traction is what gets you good times. Quick and proper shifting, assuming the given car is a manual, is what makes a high trap speed. Your car being an automatic means you only have to worry about getting a good launch.r/t 1.199
60' 2.484
1/8 9.579
1/4 14.603 @90mph
3rd run
r/t 1.061
60' 2.975
1/8 12.201
1/4 17.531
11-15-2007, 06:20 PM #17Member
- Mar 2007
- Gainesville, VA
Get rid of those tires first. You don't have the type of mods that should have you spinning halfway down the track or having to do serious peddling. Then work on your launch instead of just going WOT right off the line roll into it. The trick is to spin as little as possible while not making the car bog down too much. Sounds to me that right now you just need to work on not spinning the tires so much and most of it is your tires.
11-15-2007, 06:44 PM #18
I think you can do it, just do a minor burn out then stall the car no more than 12 to 1300 then roll into the throttle rather than just flooring as fast as you can. I ran a 12.67 @ 110 on street tires with a 2.73 with a 1.89 60' with a lid, lt's, duals and a tune. Just practice on the street a little and you'll be fine the next time you go to the track. Remember if it starts spinning, level the throttle off don't put it on to the floor.
11-15-2007, 07:38 PM #19
need to work on launching!
M6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
11-15-2007, 09:11 PM #20Awaiting Activation
- Mar 2006
- LS1 land
going back to the track
By fastt in forum Camaro / SSReplies: 6Last Post: 09-04-2010, 09:35 PM -
back from the track!!!!!!!
By 98_ls1maro in forum Drag RacingReplies: 49Last Post: 10-07-2007, 08:09 PM -
just got back from the track
By 01outlaw in forum Camaro / SSReplies: 12Last Post: 06-18-2007, 03:30 AM -
Just got back from the track:
By MarkuzLS1 in forum Drag RacingReplies: 6Last Post: 06-17-2006, 12:14 AM
