Results 1 to 20 of 24
10-20-2007, 06:24 AM #1
- Oct 2007
- Macomb, Michigan
Black on Black- 2001 ~ T/A ~ WS6 ~ M6
Looking for 2001, WS6 Engine Specs.
I have a completely stock 2001, Firebird TA, WS6, 6 speed, LS1.
Does anyone out there in LS1 land have the specs. for this engine? Meaning cam specs., bore specs., head specs., etc, etc, etc.
If not, does anyone know where I can get it?
Thanks...
10-20-2007, 10:07 AM #2
Gotta love factiry service mamulas some times. This is out of one for 2000 but I don''t think much would have changed from 2000 to 01
Bore: 3.898
Stroke: 3.622
Min oil pressure hot;
1000RPM - 6psi
2000RPM - 18
4000RPM - 24
Cam Specs (this is for service so some information is not there)
End Play 0.001 - 0.012 in.
Journal Diametere 2.164 - 2.166
Lift exh and int 0.292
Other possible usefull info
Valve lift intake - 0.472 in
Valve lift exhaust - 0.479
Thats all I have thats really any use possibly unless. If want any more feel free to ask.
10-23-2007, 02:26 PM #3
- Oct 2007
- Macomb, Michigan
Thanks for your time and thanks for the info.
10-23-2007, 03:45 PM #4
Your welcome. If you need anything else feel free to ask.
10-23-2007, 04:09 PM #5
engine is the same but the cam isent as hot as the 98-2000 models
10-23-2007, 04:16 PM #6
- Oct 2007
- Macomb, Michigan
Interesting. Maybe the 01's have higher compression or better induction?
10-23-2007, 04:18 PM #7
comp is the same but the 01-02 had the Ls6 intake which flows alot better then the the orginal ls1 intake
10-23-2007, 04:18 PM #8
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
the 01-02s have slightly smaller cams but better intakes than 00's, so the power pretty much equals out, but those cam numbers will be slightly off
10-23-2007, 04:19 PM #9
10-23-2007, 04:21 PM #10
hahaha mamulas
10-23-2007, 04:22 PM #11
very true but its also easier to put a ls6 intake on a 98-2000 model then it would be to put a cam in a 01-02 model about the same price tho just easier IMO tho
10-23-2007, 04:24 PM #12
10-24-2007, 12:01 PM #13
- Oct 2006
- St. Clair Shores. Michigan
LS1 Cam Specs
`98-`00 F-body Only
198/209 500/500 119.5 LSA
`01-`04 All Models
196/207 467/479 116 LSACraig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
10-24-2007, 02:38 PM #14
why would u just change the stock cam out for a stock cam? i know u would get a lil bit more out of it but would it be worth it ?
10-24-2007, 04:50 PM #15
- Oct 2007
- Macomb, Michigan
To all: Thanks for the replies. If anyone else has input, please don't hesitate.
Haven't tried any html tags; going to try a marquee. See what happens.
<MARQUEE bgcolor="blue" loop="-1" scrollamount="2" width="100%">Trial Marquee</marquee>
10-24-2007, 04:51 PM #16
- Oct 2007
- Macomb, Michigan
Bummer...didn't work.
10-24-2007, 08:22 PM #17
10-25-2007, 08:30 AM #18
does anyone know specs for an 04 ls1?
10-25-2007, 10:47 AM #19
10-25-2007, 06:52 PM #20
98 transmission into a 2001 engine. HELP!!!!!!!!!!
By 74LS1 in forum Camaro / SSReplies: 3Last Post: 07-16-2008, 01:14 PM -
Here’s the In-Depth Specs for the LS1 Engine.
By Elimin8tor Z28 in forum General HelpReplies: 0Last Post: 03-22-2008, 09:22 PM -
Engine Build pics and specs
By Redphoenix1998 in forum Firebird / WS6Replies: 36Last Post: 12-04-2007, 09:35 PM -
LS3 engine specs released today... 436HP
By 2003Firehawk in forum Internal EngineReplies: 24Last Post: 05-01-2007, 07:26 PM -
2000 LS1 Engine Specs
By Terrell in forum Firebird / WS6Replies: 5Last Post: 11-17-2006, 05:39 PM
