Thread: quick question
    Member eatsrice's Avatar
    palatine
    2001 formula firebird
    quick question
    Please only answer if you are 100% sure, because I can't afford another car right now. would it be safe to put like a 75 shot of nitrous on my 01 formula ls1 m6? it is pretty stock no cam or anything, I plan on using a wide open throttle switch and a window switch also is wet or dry shot safer? thanks!
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    question is can you handle the power of nitrous,lol hell yes it will be safe as long as you get a good tuner also you can go up to roughly 150 hp shot on stock engine some people go more but not recommended.id say wet shot,theres no guarantees with anything till you try it,good luck
    Member chuck4345's Avatar
    memphis tn
    2002 trans am ws6
    im am also looking to put nitrous on my 2001 trans am but i have the same concerns how bad will it damage a daily driver if you only use it every once in awhile i dont wanna be replacing a motor ild like 2 see opinions and horror storys if any one had a bad nitrios experience on a daily driver
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by chuck4345 View Post
    its all in the tuner,how good he is makes a difference how it runs,also if your an m6 activated by window switch low rpm nitrous on high rpm off,very easy.ls1s love nitrous .
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i've put 150 right off the bat in both of my cars. ran 250 on my all stock motor in the black car. change to a lower heat range plug. put on your safety stuff and have at it.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Wet and do at least a 100. Yes it is plenty safe buy a quality kit and have it installed by someone that is good with wiring!
    I would also recommend putting a button on the shifter or hand held on a cord in series with the wot switch so it's easy to let off the kit.
    If you read some of my other post I go into more detail on why this is a must for me and ALL cars I do for customers.
    Aug 2000
    Indy
    With a stock tune a 75 shot is safe, I've sprayed my car like 12 times already on a 75 shot. All you need for a 100 shot to be safe is check your A/F ratio. You can put a slightly bigger fuel jet in to keep it rich for assurance as well. You can go 150 as well but have all your safety stuff on line. I'm going to set mine for a 125 shot without tuning. I am going to just check the A/F and keep it rich for the spray
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    Warminster, PA
    With the safety items you shouldn't have any problems spraying your DD.
    Thanks,
    Matt
    Junior Member ARDLS1's Avatar
    Jun 2006
    houston
    maple red
    2001 formula
    You can spray a dry shot with no problem. Make sure the nozzle is before the mass air, this will enrichen your fuel trims, the cold nitrous will fake out the IAT sensor. Take 2 degrees of timing out to be sure. We have done this a our shop for years. I have been tunning LS1 for 5 years.
    Owen
    ARD
    Bragg NC
    Met. Sunset Orange
    01 SS
    I picked up a wet kit from HSW and have been spraying 150 wet shot with stock internals. So far so good. If you start with 100 you will be curious, then 125 and u will feel a lil kick then go 150 and you will be happy for a lil wihle
    J
    Bloomington IN
    so you can do a 75 dry shot on a completely stock ls1?
    Junior Member Websy21's Avatar
    Alberta, Canada
    Metallic Pewter
    2001 Trans Am WS6
    yes no prob, like mentioned above up to 150 no problem as long as you have the safety items in check and have it logged for AFR
  1. Quick Question
    By kenro23 in forum General Help
    Last Post: 04-20-2012, 07:47 PM
  2. Quick Sig Question
    By tatertot91 in forum Almost Anything Goes
    Last Post: 09-23-2009, 10:34 AM
  3. another quick question.!
    By silverWS6 in forum Firebird / WS6
    Last Post: 07-11-2009, 05:37 PM
  4. A quick question
    By ledesma54 in forum Computer & Tuning
    Last Post: 05-07-2008, 10:01 PM
  5. Quick Question About SLP Air Lid
    By aerojt in forum External Engine
    Last Post: 08-13-2007, 07:07 PM
