Results 1 to 3 of 3
10-17-2007, 05:23 AM #1Junior Member
- Oct 2007
- lexington,sc
ls1 into 94 camaro f-body with auto
K i know that i have to put the modded wiring harness in the car but im buying an ls1 with the harness for a 4l60e and that is what i have and it is coming with everything harness,ecu,k-member, radiator support and all the plug in's. Now will the harness for the ls1 4l60e plug into mine in the lt1 because i have to do the swap it needs to be done. please get back to me
10-17-2007, 10:47 AM #2
Good question, GM made some updates over the years on the 4L60E but I don't know if this affects how the harness was made or if sensors were deleted/added.
But one thing I do know,,,,your LT1 4L60E won't bolt to your new LS1 engine, as the bellhousing bolt pattern is completely different, so is the torque converter and flywheel, You are going to need an LS1 tranny reguardless anyway.
10-18-2007, 04:24 AM #3Junior Member
- Oct 2007
- lexington,sc
alright man appreciate it i found the whole setup trans motor ecu wiring harness and motor for 2300
Auto Body Shop?
By lmyers1 in forum General HelpReplies: 3Last Post: 10-04-2009, 11:00 AM -
Auto Body Repair & Body Primer Paint - Straight As
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 05-07-2008, 04:00 PM -
1968 Camaro Auto Body Repair - Structure & Color
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 04-02-2008, 08:30 PM -
1969 Chevy Camaro - Auto Body Repair - Tech
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-27-2007, 12:10 AM -
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-02-2007, 07:20 PM
