Results 1 to 2 of 2
Thread: Where to buy a bare ls1 block
10-14-2007, 06:22 PM #1Junior Member
- Dec 2006
- Castaic, Ca
My ls1 is in my rockcrawler buggy. I took a hard hit that bent my skid plate into the oil pan and in turn cracked the block at the driver side rear corner pan mounting surface (found out it was cracked because I had a bad oil leak). I've since built alot better skidplate so it won't happen again
. I took the motor to a local guy and he said he could repair/weld the crack. I also had him check the motor condition and what he found was that it needed rings and bearings. I decided to go with him and had him R&R everything plus port and polish the heads. Well, $3000 later I still have an oil leak. He is being very cool about and is willing to do all the labor for free to fix the problem correctly. I'm thinking I need to just replace the block and be done with it. So where can I get a good price on a replacement block???
10-15-2007, 01:32 PM #2
Try to find a used one. If you were closer I would sell you mine. Or you can get one for around $700 new from various sites on the net.
Need A ls1/ls6 bare block
By 98ws6zo6 in forum Parts Wanted / TradeReplies: 5Last Post: 01-27-2008, 07:35 AM -
FS: Ls1 bare block
By Lightft01 in forum Cowhands, Local Parts and Fish BaitReplies: 7Last Post: 03-28-2007, 05:27 PM -
WTB ls1 bare block
By SmokingSS in forum Parts Wanted / TradeReplies: 1Last Post: 06-27-2006, 12:14 PM -
Bare ls1 Block
By bwinch in forum Parts Wanted / TradeReplies: 1Last Post: 03-17-2006, 07:14 PM -
bare LS1/LS6 block
By jfrc2000 in forum Parts Wanted / TradeReplies: 0Last Post: 12-29-2005, 09:32 PM
