Results 1 to 18 of 18
    - = LR = - grandkodiak's Avatar
    x
    Computer people help please, Vista problems
    Hey, I just jumped on the Vista bandwagon and got a full copy of Ultimate. Just did a fresh install and am working on getting all my software up and running, but I have noticed a substancial problem. Its detecting 2687mb of RAM when I have 4 gig's in there. Hell with PAE enabled I had more then that with XP! What gives?
    down with the lot lizards blackhawk01's Avatar
    Pensacola
    2001 Camaro SS A4
    are you running 2x 2 gig sticks? or are you running 4x 1 gigs? If you are running 2x 2 gig sticks..run them on the same bus. (i.e) put them right next to each other..not staggered, try that
    Impounded 86 IROC-Z's Avatar
    Everything fiberglass
    2005 Amberlamps
    reinstall XP
    x
    no 4 1gb sticks
    x
    PS second problem... when i plug my other harddrive back in, the computer automatically boots to it and its XP Pro... i want some old files off of that drive, but its not letting me pick which drive to boot from, and there are no jumpers that i can find on these SATA drives... what gives?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Quote Originally Posted by grandkodiak View Post
    Does your BIOS see all 4 gigs? 32 bit or 64 bit of Vista?
    x
    64 bit... sees all 4gb in bios.
    heres yet another problem to add to the list... my background pictures get auto streched even in "center mode"... wtf?
    Canby, Oregon
    1999 Camaro SS-M6 #1775
    are you sharing any for video?
    I keel you! Blitzed's Avatar
    Titus,AL
    Black as Wesley Snipes
    09 Mazda 3, 12 Z1000
    Jesus... glad my shit works lol. I have the same stats as you except running 2 2 gig sticks
    Peckerhead Knighthawk LS1's Avatar
    Loveland, CO
    1999 Trans am
    Make sure you've updated your motherboard and CPU drivers to support windows vista. MORE critical if you've built your own system.
    For your sata problem, make sure your vista drive is in the sata 1 port, if your XP drive is in a lower number of the sata port it will boot off that, you can also create a boot partition in the bios, i'll have to remember how i did mine, but its a pain in the ass....I'm dual booting vista and xp, vista on a single core CPU SUCKS!
    x
    the sata orders probably the problem, didnt know it went like that, couldnt figure why the bios didnt just list the freakin things to change boot priority like harddrives have been since dos.
    as for the ram, i had twin crossfire cards so i have a gig of video ram, the computer sure as hell better not be using the sys ram too!
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    reinstall XP
    Ditto
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Your only problem is you jumped on the Vista bandwagon. Hop back over to XP for now. There are still plenty of compatibility issues with Vista.
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Wisconsin Rapids, WI
    1999 Z/28 M6
    right...to bad that microshaft made the system "look nice" on desktop instead of making the system work properly.
    Canby, Oregon
    I have built my system im running now and installed vista, have had Zero problems with it.
    so IDK
    Loveland, CO
    1999 Trans am
    Vista on Single Core CPU sucks with lots of lag issues..
    Vista on a Dual Core CPU is amazing.....other than the lagg issues with Vista i have not had a problem
    x
    correction... my bios says:
    4096mb ram
    1408 appropriated (wtf is that?)
    2688 available
    and update on the harddrive... i swapped the order and it boots direct to vista now, but the other harddrive doesnt show up anywhere, now what?
    Aug 1999
    No Where
    4096mb ram
    2688 available
    You need to tell you BIOS you are running a 64-bit OS. Or there should be some setting like "Remap Memory"
    There is a setting in the BIOS that you can set to chose the boot order.
  1. Vista gurus enter... sound problems
    Last Post: 11-07-2008, 07:31 PM
  2. Computer guru's enter, Vista 64
    Last Post: 10-06-2008, 04:22 PM
  3. Computer people enter:
    Last Post: 10-05-2007, 09:30 AM
  4. Vista gaming people enter
    Last Post: 04-02-2007, 01:48 PM
  5. Computer people come in
    By domestic rice in forum Almost Anything Goes
    Last Post: 03-23-2007, 10:25 AM
