Results 1 to 10 of 10
Thread: No stupid questions
10-11-2007, 12:49 PM #1Junior Member
- Oct 2007
- Courtenay, BC, Canada
Primer now- 1960 Sunbeam
No stupid questions
I have been told that there are no stupid questions just stupid answers. However, I feel stupid asking these ones:
I have a 95 SFI 3.4 litre that is going to be rebuilt, naturally aspirated. I have some ideas of how to do this along with some new part numbers, but am confused regarding the current heads on it.
They have the injectors, I won't be useing them so:
a. do I need to change to heads without injectors;
b. can I remove them and run it as is; (not likley);
c. do I plug the injector ports with something?
Again new to rebuilding, just enough knowledge to be dangerous!
10-11-2007, 01:04 PM #2
10-11-2007, 01:13 PM #3Junior Member
- Oct 2007
Yes, quoted the following, from Edelbrok and Jegs tech services. This setup is used on the 3.4 build of the Stalker V6 roadster. I asked them the same question but havn't received an answer yet:
Holley 0-8007 390 cfm 4 brl @ $400
Edelbrock 3789 @$115
3785 @$189.95
2112 @$140 special order
9737 @$70 special order
10-11-2007, 01:18 PM #4Senior Member
- Feb 2006
- Orange County, NY
the stock FI manifold wont work that well. It is designed to move air only. If you use a carb on it, I dont think it will work that great. Do they make a carb version of the manifold? the kit car guys are always using fwd gm engines in cars. I would check some sites out to see what people have done.
10-11-2007, 01:33 PM #5Junior Member
- Oct 2007
Manifold
Edelbrok makes a two piece manifold part#'s
350-3785 Manifold base
350-3789 Top
510-0-8007K 390 cmf Carb Kit
Cam 3790
10-11-2007, 01:36 PM #6Junior Member
- Oct 2007
http://www.stalkerv6.com
These cars use either the 2.8, 3.1 or 3.4 most are naturally aspirated small cars that go fast!!
10-11-2007, 01:40 PM #7Senior Member
- Feb 2006
- Orange County, NY
you dont need the injectors then. I guess you are running a distributer too?
10-11-2007, 01:45 PM #8Junior Member
- Oct 2007
Exactly
Correct, no injectors, hence what do I do with the holes the injectors leave when I take them out?
Need some injectors?
10-11-2007, 04:05 PM #9
If you are moving from injectors to a carb (i don't know why you would though) You need to get a new intake that is built for a carb, thus elimintaing the injector ports. The injectors do not interact with the heads at all beside spraying fuel at the intake valve. Your good to go.
10-11-2007, 05:19 PM #10Junior Member
- Oct 2007
No computer
I am resto-customizing a 1960 Sunbeam Alpine, and will not be putting a computer in it run the FI, also with the cam, manifold, carb, nitrous set up I have planned, I will run about 250-280 HP + or - on a 1850 lb street car. Do the math, it'll go fast enough for me!
turbo newbie. Stupid questions
By knightryda01 in forum Forced InductionReplies: 2Last Post: 04-27-2014, 04:19 PM -
Couple of stupid brake questions...
By PatrizioD in forum GTOReplies: 9Last Post: 03-15-2012, 05:17 PM -
Another stupid questions about cars thread.
By JoshieDoom in forum Almost Anything GoesReplies: 46Last Post: 12-02-2008, 07:26 AM -
Stupid questions....
By clg82 in forum Firebird / WS6Replies: 10Last Post: 02-19-2008, 07:32 AM -
Quick Stupid Questions
By Mr. CarelessAndImprudent in forum Almost Anything GoesReplies: 5Last Post: 12-15-2006, 01:00 AM
