Results 1 to 13 of 13
    Junior Member krazykarl454's Avatar
    quakertown PA
    weind intake Vs. fasst intake?
    so i was lookin into different intake manifolds, and i found a weind intake for a good price, and a fasst intake for a good deal? so which one you guys think i should go for?
    thanks-karl
    I wouldn't waste my time/money on the Weiand intake. If you found a good deal on a Fast, I would pursue it.
    Painted manta stripe
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    Weiand makes a prettier manifold, but it'll need porting to flow the same numbers as a stock FAST. If you're into show though, and you're going with a mild setup, a fast could be more than you need...
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
    quakertown PA
    deffinetly not it for show. all about the go, ya i notived the weind is aluminum, which also transfers heat better then the composite ones, which is not so good for keeping your intake charge as cool as possible. well thanks guys
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    unless you plan on camming the car and such, the fast really isnt worth the price unless your getting a really good deal.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    quakertown PA
    well i'm in the middle of buying a 99 z28 with all sorts of SLP bolt on shit, and that weind intake is one of them. so hopfully tomorrow i'll be driving around in my new Z. but my friend has a fast intake cause he went with a blower, so i could get my hands on one, but i'll probly leave the weind on, cause its definetly getting a cam and sum headers once i save up sum more bucks. I guess the plus side of the aluminum intakes are you can port match them to the heads.
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    Quote Originally Posted by krazykarl454 View Post
    I think you got that backwards the composite will transfer/disipate the heat better than the aluminum. There are no facts that say one transfers heat better than the other but it seems to be a good majority like the composite over the aluminum. The fast is the clear choice for an intake if you have the money. As others stated it only worth it if you plan on some heavy mods like a cam and heads. If your just doing bolt ons its kinda a waste of money.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    quakertown PA
    well when i say transfer heat better. i mean that in a bad way for your intake charge. the composite won't transfer the heat to the trottlebody, as much as an aluminum will. thats why they went composite from the factory. hold a torch to one end of an aluminum rod, and hold the other end and see how long it takes to get hot(not long at all) now do it on a plastic rod(it will melt b4 the other side ever gets hot. Trust me. i would rather have a composite
    Dec 2002
    n/w chicago
    sure the metal will heat up, but the air going threw isnt even in the manifold for a second.
    Member 89LX's Avatar
    East Coast North Carolina
    Navy
    2000 Z28 M6
    Ls6
    LS6 for me
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by 89LX View Post
    LS6 for me
    the Ls6 i had on my car was very disappointing. I took it off and bought a ported FAST 90/90. i went from 409/386 to 444/395 after install and reutne. now it feels like how the car should have been all along...
    2013 ZL1: °°590rwhp/576rwtq°°
    Navy
    2000 Z28 M6
    Air In.....Air Out
    If the engine work has progressed to the point the LS6 will no longer support the mods, that will certainly be the case.
    DFW
    '18 CTS-V
    '13 ZL1
    just a basic H/C car. 224 cam and patriot heads. went from the Ls1 to the Ls6, and it didnt seem like it was all there. that's why i went FAST...
    remarkable because alot of people run H/C cars w/the Ls6 intake and are happy w/it...
  1. BBK SSI Intake, vs Holley Intake, vs LS6 intake, vs PP 96mm
    By Lunatikgixxer in forum External Engine
    Last Post: 02-28-2017, 10:39 AM
  2. Weind VS LS6 Intake
    By fastfirebird2002 in forum External Engine
    Last Post: 05-04-2009, 06:23 PM
  3. Single Plane Intake VS Stock PP Intake
    By xzaero0 in forum Forced Induction
    Last Post: 11-27-2007, 07:00 PM
  4. weiand/lingenfelter intake or ls6 intake?
    By sosacorksthebat in forum External Engine
    Last Post: 06-18-2007, 03:50 PM
  5. Difference in Stock Ram Air intake and other aftermarket intake
    By WS6-cobra killer in forum Firebird / WS6
    Last Post: 01-15-2007, 06:47 AM
