Results 1 to 10 of 10
    Long Island, NY
    Underhood belt squeak
    Anyone know what component is likely to cause a belt related squeak/chirp? I notice it mostly at idle. Are the belt tensioners a know culprit or is there an idler pulley as well that could cause it? Its a 2000 with 32K. Ease of replacement comments. It's no 69...
    Thanks,
    Jack
    old timer blue02Z's Avatar
    2002 Z28
    well considering i have no idea what it is except for an ss i assume its an ls1. i would replace both belts. its easy took me about 5-10 minutes
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    it is a 2000, 7 year old belts. i would replace them both.
    www.eautocad.com
    FL
    1998 Camaro Z28
    mine does the exact same thing, at idle, its like a grass hopper chirp or a bird squawk. I'm going to try some grease-less lubricant and see what it does.
    2002 Z28
    if you try anything, try belt dressing. i would just repalce them. belt dressing is like band-aid
    www.eautocad.com
    FL
    1998 Camaro Z28
    yeah i think the lube/belt dressing might cause some slip and reduced power to the equipment being ran from the belt. I'm going to AA tomorrow to get a new belt.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I've heard tons of LS1's that have the squeak from the belt at cold startup, mine included.
    I put belt dressing on it and it went away for a short while, so I think its the belt. Try something like Goodyear Gatorback, which is supposed to offer superior traction to a regular straight ribbed belt.
    Member jamessr's Avatar
    Newport News, VA
    2000 Trans AM
    +1 on the Goodyear Gatorback.
    Also when your belt is off turn your idler pullies by hand. If you hear any noise what so ever, replace it. I just done that about 3 weeks ago and it made a world of difference. No more chirps at idle or a cold start. The pulley on the belt tensioner was the worst.
    San Antonio, Tx.
    2001 T/A WS-6
    If you're going to do one pulley, do them both. The tensioner pulley and the idler pulley. I did both of mine and I still had the dreaded squeal/squeek/bird chirp. So what I did was replace the belt with a Goodyear Gatorback belt that I got from A-zone.
    Chirp all gone.
    West Virginia
    Y2K WS6
    Replacing the pulleys is easy as is the belt. while replacing your belts try giving the Idler pulleys a good spin.. if they spin a lot the bearing is probably bad or going to be. I know the idler is like $21.00 and not sure about the tensioner it's easier to get to. My squeek has been driving me NUTS. so I've replaced just about everything as soon as i figure out how to get the little belt off I'll be a happy camper
  1. Question: Are these 2 computers underhood OBD 11 ?
    By denegrader in forum Camaro / SS
    Last Post: 05-30-2011, 01:04 PM
  2. Question: underhood
    By pewter Z28 in forum Camaro / SS
    Last Post: 04-08-2011, 05:14 PM
  3. 08 Vette Procharger annoying belt squeak?
    By Joe00SS in forum Forced Induction
    Last Post: 06-11-2009, 12:12 AM
  4. Underhood belt squeak
    By jacks_ss in forum New Member Introductions
    Last Post: 10-08-2007, 04:07 PM
