Results 1 to 3 of 3
Thread: AC Diagram
10-06-2007, 05:55 PM #1
AC Diagram
Is there one on line somewhere for the inside stuff, like the evaparator and interior air intake?
Also do we have a cabin filter?
10-07-2007, 09:23 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
No cabin filter. Are you just getting a musty smell from the vents or something? If that's the case make sure the evaporator condensate drain on the passenger side firewall isn't clogged and dripping inside the car. Something else you can do is pull out the blower fan motor and check inside it for any debree - I've had small wet leaves in mine before. Just disconnect the motor connection, remove 3 bolts and the motor and blower pull right out.
10-07-2007, 08:53 PM #3
I will have to try to find where it's at in the car. Seems pretty well hidden.
Wiring diagram
By Ironwolf in forum Stereo and ElectronicsReplies: 3Last Post: 07-13-2009, 09:40 PM -
Help: A/C diagram
By dan_golo in forum Camaro / SSReplies: 0Last Post: 06-29-2009, 07:33 PM -
Wiring Diagram for 02 ls1
By Black02TA in forum General HelpReplies: 1Last Post: 06-29-2008, 04:32 AM -
Need Wiring diagram
By SOMBV in forum NitrousReplies: 1Last Post: 11-07-2007, 02:52 PM -
ls1 engine diagram
By 01ls1ws6 in forum General HelpReplies: 4Last Post: 10-26-2007, 11:55 AM
