Thread: Loose Steering Column, Help
10-06-2007, 03:47 PM #1Senior Member
- Dec 2006
- Deltona, FL
Sebring Silver Metalic- 2002 Camaro Z28
I noticed when I bought my 99 Z28 the steer wheel column was a little loose. Well I say loose because I don't know how to discribe it. It kind of wobbles down and up a tad. It is almost as if a gorilla was using the steering wheel when getting in and out of the car.
I heard it could be the bolts that hold it in, four i think. Is this common, provided you're always yanking on it to get in and out?
A local shop sad it is preventing them from getting a true center steering wheel alignment. They said its becuase of the play up and down. Something about when you step on the break it goes up and centers. When you let off the break i guess it must slip down a tad and goes left. Just trying to reitterate what they tech said.
They said it could be bad beerings? They said they have no clue until they take the whole thing apart. suggested buying the unit from a u-pull-it yard cuz i could end up in the 800-900-1000 dollar range by the time they are done figuring it out. Ugh. The up and down doesn't bother me, cuz i don't hang on the wheel. The left of center in the steering wheel is what bothers me.
Any thoughts?
Thanks
kool-aide
10-07-2007, 08:46 AM #2Senior Member
- Feb 2006
- Orange County, NY
some of the older 70's and 80's cars had that problem. the bolts would come loose and the steering wheel would move up and down. It required pulling it apart and tightening the bolts, with loctite added. The problem was then solved. I had a car that did this but never noticed the pull to the right or left.
10-07-2007, 01:29 PM #3Senior Member
- Dec 2006
- Deltona, FL
It doesn't pull to the left, the wheel just points a little off center to the left. For the most part she drives straight as an arrow.
Thanks for the info. Since I came across a firebird with the same problem, much worse. I thought it might be common and have a common fix.
10-09-2007, 04:26 PM #4Junior Member
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
Get a Haynes manual. Has step by step instructions with pics to get to the bolt, bolts that get loose. You'll need a steering wheel puller and another puller, can't remember off the top of my head the name of the othe uller. Mine moves down and to he left about 1/4 inch. Just had the frontend aligned and they said notta. If mine get worse than I will have to deal with it.
10-10-2007, 04:07 PM #5Senior Member
- Dec 2006
- Deltona, FL
ok, I have the haynes, didn't look though. If it is the four bolts, e.g. common fix to this problem, then great. I'll check my Hanyes, and not for streaks. I have a steering wheel puller, kind of universal i think. I used it back when i had a 67 Firebird. That was the first and only wheel i ever pulled. I was impressed how easy it was. Air bags, um makes me nervous as hell. I guess the important part is to disconnect the batter first, and read the manual.
thanks
kool-aide
01-08-2008, 07:14 PM #6
did you fix the problem
just wanted to see if haynes worked if it was just the screws an easy fix for the ones with the same problem.. Great discription on "gorilla using the steering wheel to get in and out of the car" LMAO on that.. I have the same problem as you it just has play doesnt bother me much but if I can fix it, I will..
Jgarza
Loose Steering Column???
By supercharged666 in forum General HelpReplies: 21Last Post: 12-27-2012, 12:27 PM -
02' steering column
By johnfin in forum Firebird / WS6Replies: 3Last Post: 08-17-2012, 06:15 PM -
97 GMC Steering column
By 1998 T/A in forum Parts Wanted / TradeReplies: 2Last Post: 04-24-2010, 08:48 AM -
Will this steering column fit
By shanepatrick1230 in forum Firebird / WS6Replies: 0Last Post: 09-15-2008, 05:23 AM -
Need steering column
By los41682 in forum Parts Wanted / TradeReplies: 3Last Post: 06-13-2006, 07:33 PM
