Results 1 to 20 of 22
    Georgia
    2014 Camaro 1LS
    Free Ram Air Modification
    does it really make a difference ?
    Member 98_ls1maro's Avatar
    I just did mine 2 days ago, and tell you the truth I didn't feel anything. I think it might a couple of horses, so its not enough to feel.
    Member 2fast2blegal's Avatar
    San Antonio
    pewter
    2002 Trans Am
    what is it???
    San Antonio
    pewter
    2002 Trans Am
    didn't work
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by 2fast2blegal View Post
    what is it???
    http://www.installuniversity.com/ins...sity/index.htm
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    It does not give a SOTP gain but it does work.
    Aug 2000
    Indy
    It's 2007 and people are still askig !
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    hahahahaha! it helps but there are other ways to get more horses.
    old timer blue02Z's Avatar
    2002 Z28
    it helps.... get your filter more dirty
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by 7camaro7 View Post
    what u laughing at ????? whats up my friend
    no more 4th gen secondgearscratch's Avatar
    Jun 2006
    St. Louis, Missouri
    2000 z28
    in a word....
    NO.
    Nashville, TN
    02SS6spd VERT!
    Man, I'm at work waiting on 10pm... That free ram air mod is ok. I'll show you my intake the next time I see you.
    Georgia
    2014 Camaro 1LS
    at least u can get online
    bay area
    1999 Hardtop Z28
    Quote Originally Posted by blue02Z View Post
    yeh...do it if you like banging the dirt outa your filter every month...i just did that and it looked like the mats on the driverside floor.
    Member jag42420's Avatar
    Aug 2006
    Kentucky
    2002 WS6 Trans Am
    On a WS6 you're better off sealing the hood and debaffling, I'd assume the SS is the same. If you do not have a SS/WS6, the FRA mod is better than stock, but not as good as FTRA or SSRA since it pulls in hot air.
    `98 Formula M6 HdTp
    It only Pulls in Hot air off idle.
    Once the car is moving it pulls in cold air.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Nashville, TN
    02SS6spd VERT!
    Randy, try not to do anything till I show you mine man. I've got LOTS of intake work done! You know the black air dam that sticks out at the bottom of your radiator? I've even replaced that with a no flex metal one. Up from that I've got the Fast Toys Ram Air and above that I've got the kn filter and the lid. Next I'll be doing that throttlebody bypass mod, port and polish the throttle body, and then the intake manifold.
    But for what I've got done right now, you've GOT to see it. Right now I'm trying to get this clutch master cylinder thing worked out and then I'll be killing rubber again.
    by the way, I think the VERY next thing I get will be GMMG. I listen to it everyday online! I've even gotten used to it so when I hear any other cars out on the street, they don't sound right! I've been hearing NOTHING but gmmg everyday and just now I had some $$$ but things started messing up due to the stage 3 clutch in there so its necessary to replace the clutch slave cylinder and the clutch master cylinder. Hopefully this'll fix all my problems though.
    Georgia
    2014 Camaro 1LS
    GMMG ?
    Nashville, TN
    02SS6spd VERT!
    GMMG ?
    http://gmmginc.net/media/Video/
    nuff said. They've got the catback I want. $700 and personally it sounds better than loudmouth.
  1. New modification?
    By TLS_Addict in forum Almost Anything Goes
    Last Post: 03-01-2011, 06:03 PM
  2. My latest modification
    By wooddaniel in forum Firebird / WS6
    Last Post: 09-01-2010, 04:35 AM
  3. Hood Modification
    By matthewaqui in forum Firebird / WS6
    Last Post: 05-06-2008, 05:12 PM
  4. My WS6 Modification Idea
    By SoCalTom in forum Appearance Section
    Last Post: 05-04-2006, 09:40 PM
  5. LS1 modification...yes or no...what do you think
    By LS1 SEAN in forum External Engine
    Last Post: 10-29-2005, 12:56 PM
