    Marshfield Missouri
    sub frame connectors
    i just needed some opinions on sub frame connectors, the best brand and how hard are they to install.
    Senior Member splitfinger09's Avatar
    Bartlesville, Oklahoma, United
    Bright Rally Red
    2000 Camaro SS #5075 M6
    Quote Originally Posted by 01tao6gto View Post
    I got a set of grantelli SFC's through the group buy on this site for $100. I would def suggest you get a weld in set. I dont know how to weld so I had to take it to a shop. Prices on install seem to vary alot.
    down with the lot lizards blackhawk01's Avatar
    Pensacola
    2001 Camaro SS A4
    what exactly do they do to help? do they help for the torque and body twists?
    Bright Rally Red
    Quote Originally Posted by blackhawk01 View Post
    Absolutley neccesary to keep your f-body from stretching and twisting. You go to long without subframe connectors and you will start to lose your door to fender gaps and your t-tops will start leaking. This is especially true if you are more than stock power. SFC's will also make your car handle better, you'll get fewer squeaks and better traction. Def a good mod...
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Helps get power to the ground as well.
    Question: this guy has a 94 camaro M6 with t-tops. Pushing atleast 417 to the wheels. First of all he says he has 3.73 gears? I dont know why but how would 3.73 gears go with the M6. Another thing is that he says he has too much power for sub frame connectors and it will mess up the car or something. Is there any cases where that is true?
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    I just put a set of weld on BMRs on my 2002 not a huge difference, granted I am mostly stock. However, the car does feel a little bit firmer, but nothing drastic.
    I do believe some 94s came with 3.73s. I need to do more research but my old 94 B4C M6 turns higher RPMs while cruising then my 02, and I don't think they were changed by the old owner.
    Member blownh2x's Avatar
    Joliet,IL
    99 Firehawk (M6) #518
    Quote Originally Posted by JwMonE99 View Post
    I had a 94 Z28 with 4:10 gears and sheared a tooth off power shifting 4th gear and I decided to go with 3:73 gears and an auburn posi. The 3:73 worked nice for an all around great gear ratio with the M6. I can believe him on the gear ratio.
    Bright Rally Red
    Question: this guy has a 94 camaro M6 with t-tops. Pushing atleast 417 to the wheels. Another thing is that he says he has too much power for sub frame connectors and it will mess up the car or something. Is there any cases where that is true?
    SFC's are there to prevent you from twisting your car into a pretzel. The more power your pushing it seems there would be more of a need for them. Im not 100%, but that sounds like B.S. to me.
  1. Sub Frame Connectors
    By Trans Am WS6 in forum Suspension and Handling
    Last Post: 08-21-2009, 04:57 AM
  2. Sub Frame Connectors
    By MIKEY'S 2002 TA in forum Parts Wanted / Trade
    Last Post: 12-29-2007, 08:21 PM
  3. Sub Frame Connectors?
    By LS1Powerhouse in forum Suspension and Handling
    Last Post: 08-04-2007, 01:08 AM
  4. f/s sub frame connectors
    By nirvana91 in forum Parts For Sale / Trade
    Last Post: 05-07-2006, 04:19 PM
  5. f/s sub frame connectors
    Last Post: 05-03-2006, 06:08 PM
