Thread: trans am/firebird power antenna
09-30-2007, 11:53 AM #1
well i just bought one off the web....is there any thing tricky about installing it!??!any write ups ,stickies?!?1any help would be greatly appreciated
09-30-2007, 12:00 PM #2I see Yello and I like it
- Mar 2007
- Ontario, Canada
yellow- 02 Collector Trans Am
its extremely easy. Just unplug the anntenna and power plug in and it will pull out. Youll need to take your spare tire out of course (while its out you might as well make sure the psi is up just incase). Good luck.
09-30-2007, 12:01 PM #3
oh ok..thx man... psi for the spare..right?
09-30-2007, 12:17 PM #4I see Yello and I like it
- Mar 2007
- Ontario, Canada
yea..they loose there air pressure from sitting in the back so long. There is nothing worse then having a flat tire and u go to change it and only to find out that your spare is also flat.
09-30-2007, 12:34 PM #5
Simple install. Its only held in by a nut on the outside of the car (remove with a small adjustable wrench) and a 10mm screw at the bottom of the assembly. Then you unplug it and pull it out (getting the rubber grommet out is the trickiest part).
1998 Trans Am, A4, SLP Loudmouth I, US Exotics WS9 ram air hood, Volant intake, 3.23's, 70k miles
09-30-2007, 01:33 PM #6
Couldn't be easier. Took me 5 minutes to swap mine.
Wanted: Power Antenna (#10402860) for 01 Trans AM
By funrudy in forum Parts Wanted / TradeReplies: 2Last Post: 03-27-2010, 05:08 PM -
Convert power antenna to fixed antenna
By Red 99 T/A in forum Firebird / WS6Replies: 21Last Post: 01-24-2009, 10:40 AM -
trans am power antenna
By 35thAnniZ28 in forum Firebird / WS6Replies: 2Last Post: 09-30-2007, 07:27 PM -
97+ power antenna
By 97RAMAIRTA in forum Parts Wanted / TradeReplies: 1Last Post: 01-31-2007, 07:42 AM -
Need Power Antenna, Ashtray lid, and driver seatbelt latch black for 2000 Trans am
By tcossair in forum Parts Wanted / TradeReplies: 4Last Post: 03-30-2006, 06:50 AM
