Thread: rpm activated switch
09-29-2007, 07:46 AM #1Awaiting Activation
- Aug 2007
- odessa,texas
69 hugger orange- 98 z28
the guy at jegs said that the regular msd rpm switch with the on and off would work for my 01 but i cant get it to activate and the n20 system operated when i set the wot switch, do ineed the one thAT says dis/rpm
10-10-2007, 06:17 PM #2
Not sure if its an option on the msd switches, but i picked up a Hsw switch and i had to put it to 4cyln mode to get it to activate and its been good to go since then.
10-10-2007, 06:24 PM #3
for LSx equipped vehicles, it needs to be set for 4 cylinders.
10-12-2007, 10:19 AM #4
been a long time since I installed mine, isn't it a wire loop that you have to cut? can't remember
10-12-2007, 10:22 AM #5
Correct!
Yes there is a couple loops. I cut makes it a 6 cyl 2 makes it 4.
CYLINDER PROGRAMMING
The Switch is programmed for 8-cylinder applications, however it can be used with 4 or 6-
cylinder applications. To program the Switch for different applications, the cylinder select
loops must be modified as shown in Figure 2. After cutting a wire loop, seal the wire end
with the supplied heat-shrink caps. Use a heat gun or other heat source to shrink the cap
for a good seal.
10-12-2007, 10:54 AM #6
ah, that's right, I remember now. It was late '03 when I installed my kit, lol
Help: engine boggs when a/c is activated
By greg v in forum General HelpReplies: 3Last Post: 05-11-2009, 09:34 PM -
MSD Digital RPM Activated Window Switch
By WS6ICK in forum NitrousReplies: 4Last Post: 07-30-2008, 06:24 PM -
NOS rpm activated window switch
By oneBADDz in forum Parts For Sale / TradeReplies: 6Last Post: 12-01-2007, 09:46 AM -
WTB: FPSS & RPM activated switch
By MagicMan in forum Parts Wanted / TradeReplies: 0Last Post: 09-12-2006, 11:28 AM -
Theftlock activated/ do not know code
By Tom's 99TA in forum General HelpReplies: 8Last Post: 12-10-2005, 05:35 PM
