Results 1 to 1 of 1
09-29-2007, 06:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
1972 350 Chevrolet Pickup Engine - Tech - Build Your First Engine
Lucky you, you're about to do something that only comes around once in any hot rodder's life: building your first engine. You see, if you stay at this game long enough, you reach a point when the thrill of discovery fades a little bit. Oh, it's always a buzz when you twist the key on your latest creation, but there's nothing like that first build. So savor the moment and tag along as we rebuild this 350 small-block and show you some tricks and tips we've learned over the years.
Keep in mind, while you can do most of the disassembly and reassembly in your garage-or kitchen, if she's a particularly forgiving gal-several operations can only be performed by a competent machine shop. With help from the crew at JMS Racing Engines, we'll walk you through them so you know what your particular engine needs and you can discuss the work with your machinist.
Selecting a rebuild candidate shouldn't be too hard, thanks to the millions of small-blocks turned out in the five decades since its introduction. The best scenario is to pull an engine from a running car or truck; this way, you can listen for smooth combustion, observe the oil pressure and coolant temperature behavior, and get a solid sense that there's nothing terminal going on inside the block. Buying beached whales-you know, those engines sitting loose on the ground at the swap meet-is much riskier. Your only assurance that there are no cracks, warps, or fractured parts is the seller's word. Choose wisely and make sure the seller will refund your purchase price if terminal illness is lurking. Keep walking if it's an as-is deal.
The subject for this story is a '72 vintage two-bolt main 350 we yanked from a Chevy pickup street rod. It ran pretty well but had a nasty habit of fouling the No. 8 spark plug every few thousand miles. Aside from that mystery, it had good acceleration, the oil pressure read 25 psi at idle/60 psi cruising, the temp gauge lived at 190 degrees F, and it didn't make any sick noises. But it was tired, and that No. 8 hole wasn't going to fix itself. We could make it better, and so can you. Let's dig into the engine and rebuild the short-block. Next time, we'll revive the top end and prove our efforts with a dyno session.
WHAT IT COST • SHORT-BLOCKBLOCK'72 Chevy passenger car, two-bolt mains, 0.030 oversizeON HAND
POWERHOUSE 383 KIT$879Powerhouse cast-iron 3.750-stroke crankshaft, 400-style 8-inch balancer, 400-style 168-tooth flexplate, and forged 5140 steel 5.7-inch rods; King tri-metal, chamfered for radiused crank rod bearings; ARP 31/48-inch rod bolts; forged aluminum four-notch flat-top pistons; press-fit piston pins; Hastings moly- faced 2M139-030, 51/464, 51/464, 31/416-thick rings; King tri-metal, chamfered for radiused crank main bearings.
MISCELLANEOUS ITEMSMain caps & fastenersStock Chevy two-bolt caps and boltsRear main sealFel-Pro BS40013$8.78Cam bearingsDurabond CH-8 $19Plugs & pinsMisc. block plugs and dowel pins (Pioneer)$15Engine paintAervoe Chevy Orange$4.95 BOTTOM END TOTAL$926.73MACHINE WORK Disassemble and hot-tank engine parts $125Pressure test $60Magnaflux inspection $35Machine cylinder decks $100Machine crankcase for rod clearance $125Line-hone main bearing saddles and caps $150Torque-plate hone cylinder bores $200Install press-fit piston pins $40 MACHINE WORK Total$835 GRAND TOTAL$1,761.73
383CI Small-BlockBuild Sheet
Specifications not listed are the same as stock. Except as noted, all dimensions are in inches or fractions thereof.
Displacement383ciBore x Stroke4.030 x 3.750Compression10:1Rod, center-to-center5.700Piston deck height0Rod bearing clearance0.0026Crank endplay0.0060Piston ring endgap0.022 top; 0.018, secondPiston to wall clearance0.002Main bearing cap torque70 lb-ft* Rod bolt torque45 lb-ft* *moly-lube
Photo Gallery: 1972 350 Chevrolet Pickup Engine - Tech - Build Your First Engine - Chevy High Performance Magazine
More...
How To Hot Rod Any Engine - Engine Tech
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 01-18-2011, 10:20 PM -
1972 Chevy Nova LSX Engine Swap - Modernized!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-29-2009, 10:30 PM -
Small Block Chevy Engine - Build Your First Engine - Tech
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-30-2008, 07:50 PM -
Engine Dyno - Build Your First Engine
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 12-05-2007, 06:50 PM
