Results 1 to 1 of 1
09-29-2007, 06:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
C4 Corvette Plastic Repair - Spastic Plastic
Over the years, we've done quite a few interior restorations with pleasing results. Then, along comes the C4 Corvette with a whole new set of problems to deal with. Sure, while the '77 and later sharks started using more plastic than ever before, the C3 plastic material seemed tougher than the C4 interior pieces. Since the flat-dash C4s are approaching their 20th birthdays, many of their interiors need help.
With all the C4s being cut up for Vette Rod suspensions, you'd think a lot of decent plastic interior pieces would be available. The problem is, almost all of the interior panels are cracked and broken. We've dismantled our share of early C4s for Vette Rods, and some pieces are always broken, no matter how nice the car is. A good example is the sill-panel cover on the '84-'89 cars, especially on the driver side. How many of these do you see in good shape? Not many.
We've tried Super Glue and model cement to stick plastic pieces back together to no avail. Then, a few years ago, a mobile tool supply van rolled in with a plastic welding kit, which we decided to try. We pulled out the directions and were immediately intimidated by the product. While the welding would be relatively easy, the brainteaser was determining which plastic we were working with.
Unfortunately, there are many plastic compounds; some melt and bond together and some just burn. In the instructions were questions such as: Does it smoke or bubble when heat is applied? Included were eight different sticks of plastic compounds to determine what works best. (We eventually discovered that the plastic welding kit worked perfectly for modifications on Optispark distributor caps.)
Another problem was, if the repair was visible inside the car, it was usually hideous. We discovered that both sides of the crack required welding for durable repairs. Subtle tricks might work, including heating the weld spot, then applying vinyl to re-create the grain. Unfortunately, applying heat improperly can make a small concern become a heartbreaker.
While at SEMA last year, we found a plastic repair kit like no other. Tim, from G.T. Motorsports, was repairing broken plastic housings and re-creating broken-off plastic tabs with ease using Plastex. We were intrigued because it appeared he was making plastic right in front of us. Within a few minutes, we were making plastic tabs ourselves.
As Tim explained, the substance is made with tiny plastic beads and a catalyst. The pieces we repaired were stronger than the surrounding plastic. The Plastex repair kits come in clear, black, and white. If you need another color, coloring agents are available. Since Plastex is a true plastic, you don't need to know the type you're repairing. The same repair procedure applies to all plastics.
The beads are in powder form and, when the catalyst is applied, it reacts to create plastic and bond to the surrounding material. When the catalyst is first applied, the mixture feels like soft plastic that's been heated. After the reaction takes place and the repaired piece cools (the chemical reaction causes heat), the Plastex is as hard as the surrounding plastic.
We put one of the kits to the test. The instructions are simple, but your first repair should be on something disposable. To our surprise, the repair kit worked at the shop just like it did at the show.
Using the catalyst and powder takes some finesse, but once you get the hang of it, the sky's the limit. Give the repair some time to set up, and don't be in a hurry to put the part back in use. The repaired piece becomes hard when it has finished its chemical reaction, which usually occurs in 15 minutes.
We tested the Plastex kit on a glovebox door that was broken at the plastic hinge, and so far it's held up to heavy abuse (for testing). If you want to permanently repair the plastic parts in your Corvette, Plastex is the fix. The kits are reasonably priced at $9.95 for small repairs and $24.95 for large. Shop kits for major repairs are also available.
Photo Gallery: C4 Corvette Plastic Repair - Corvette Fever Magazine
More...
Clear plastic repair?
By DADCRUISER in forum Appearance SectionReplies: 6Last Post: 08-04-2015, 06:56 AM -
Plastic ar lower
By Modulistic in forum Gun's & AmmoReplies: 2Last Post: 03-06-2010, 04:30 PM -
plastic for my dashboard
By ls1_formula98 in forum Firebird / WS6Replies: 2Last Post: 10-03-2008, 05:03 PM -
Repair Plastic Bumper on DD??
By Commie in forum Almost Anything GoesReplies: 7Last Post: 08-19-2008, 06:00 PM -
Question: black plastic
By niterunnr in forum Camaro / SSReplies: 1Last Post: 07-06-2008, 03:53 PM
