Results 1 to 1 of 1
Thread: Making Your Corvette Invisible
09-29-2007, 06:50 AM #1Blown, Stroked, & Sprayed
- Aug 1999
- No Where
We recently ran a press release for the new K40 Electronics Calibre Radar and Laser Defuser protection. Due to the ever-present threat of speed traps and the tendency for Corvettes to exceed the speed limit, we decided to try this new product out on Project Shark Attack. K40 promptly sent us their Calibre SL with the Front Laser Defuser system. On a basic level, the K40 protection system is minimally invasive as it uses the new Blue Tooth technology to ease your installation woes. This saves quite a bit of time during the install. There are no holes to cut or drill for cabling, plus there is less wiring to conceal. The K40 interior network module is easy to place, and we all know how limited the interior compartment and underdash area of Corvettes are. The Blue Tooth technology not only saves wiring time under the dash and externally, but the K40 Blue Tooth signature is unique so it won't interfere with the multitude of RF signals occurring under the C4, C5, and C6 Corvette dashes. That is a huge plus when compared to competing systems.
Installation can be completed in one day depending on how fancy you get with the receiver installation. The front and rear radar receivers use a 12-volt battery or ignition power so there's flexibility in the wiring, and the only other wire to install on the car itself is the ground wire. We decided to use ignition power from the cooling fan relays to power our radar receivers. If battery power is easier to access on your project, you can use that. Wherever you decide to mount the receivers, keep in mind that although they're not heavy, a good sturdy mounting point ensures long, dependable receiver life. If the radar receivers or laser defuser move out of position, erroneous info will be given, and you may not get the radar info you need.
After the K40 system was installed, a road test was in order. We first began with the system start-up, and the initial wakeup sequence went into action. We made our initial system selections and then headed out for the testing. The very cool K40 Calibre remote control allows you to switch from low to high volume (or mute if you prefer) along with voice and tone modes. The remote is simple to operate and easy to understand with its voice prompts. The first thing we noticed was the Calibre's city mode was quiet heading to the highway, as very few false signals were triggered. We switched over to the highway mode, and Calibre verbally announced "highway." We then picked up speed and cruised with the rest of the pack on the interstate.
Although the K40 Electronics Calibre system is relatively new to PSA, we're impressed with the few false alerts and the many warnings on the open road that proved we were under radar surveillance. We'll be testing the system extensively during the upcoming show season, as you all know how it is when you're on the open road. Speeds tend to creep up, and you can get zapped when you least expect it. As we learn more about the Calibre system, updates will be forthcoming.
K40 Electronics feels so strongly about their Calibre system that a speeding ticket warranty comes with the product. Obviously, the parameters are limited somewhat as K40 will not pay a speeding ticket issued for excessive speed in a school zone, construction zone, or if a DWI/DUI is involved. We all realize that no one ever goes over the posted speed limit, but out in the real world try going 65 mph on the interstate. If you're not cruising at 80 mph, you'll be run over. You got to go with the flow, and the Calibre system helps you do just that!
Photo Gallery: Making Your Corvette Invisible To Radar And Laser - Corvette Fever Magazine
More...
invisible car technology
By 0rion in forum Almost Anything GoesReplies: 6Last Post: 04-16-2014, 01:28 AM -
Invisible Aluminum
By Goat-E in forum Almost Anything GoesReplies: 24Last Post: 08-01-2009, 07:01 PM -
Purpose of Invisible mode?
By SexOnWheels in forum Almost Anything GoesReplies: 25Last Post: 03-02-2007, 07:38 AM
