Thread: Need More Info.......
09-25-2007, 06:27 PM #1
I need a little more input on an ls6 intake swap i am about to do. Looking over the directions i acquired from ls1howto.com i can fully understand everything until i get to the point about the coolant lines!! I am having trouple understanding how to install the new coolant lines. If anyone has any suggestions or other websites i could use for further information. I would appreciate it!!!
09-26-2007, 11:11 AM #2
09-26-2007, 02:16 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
Once you get the intake off you'll see the stock pipe is just bolted down at each corner. You use the same holes for the rear plugs and the smaller front pipe. Some people just leave the stock pipe there and remove some material from the bottom of the LS6 intake instead - but be careful if you go that route. On the couple I've helped install we used the 01-02 plugs/front pipe. If you have any problems just post up...and be careful not to become a member of the "I broke my oil pressure sensor club."
09-26-2007, 02:22 PM #4
09-26-2007, 03:00 PM #5Senior Member
- Jul 2005
- Jacksonville, FL
They sell them...whether they have them in stock or not I don't know. GM has changed the part numbers several times, not sure if the ones listed on howto are current - give your dealer a call with them and see what they say.
09-28-2007, 10:47 AM #6Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
I believe I ordered my LS6 coolant lines from the WS6store.com has the front line and the two rear plugs.
New here, I'd like more info on my car.
By neomoon in forum V6Replies: 3Last Post: 10-10-2007, 03:05 PM -
Need some info please?
By blackSS01 in forum DrivetrainReplies: 0Last Post: 08-05-2007, 07:08 PM -
need more info
By bmwmteam in forum Firebird / WS6Replies: 2Last Post: 06-22-2007, 10:42 AM -
Anyone have any info? (Computer info)
By blackSS01 in forum Almost Anything GoesReplies: 3Last Post: 02-01-2007, 02:44 PM -
need some info on a F1 Z28
By 2000PEWTER,WS6 in forum Camaro / SSReplies: 6Last Post: 07-30-2006, 08:09 PM
