Results 1 to 10 of 10
    Junior Member MCCs WS6's Avatar
    Chicago(Bridgeport)
    01 T/A WS6
    trans not shifting to 3rd at wot
    i put a cam and heads on my 01 ws6 .. the guy who did my tune raised the shift points when tuning.. first time i drove it i noticed that if i went through the gears at wot it would go through 1st and 2nd and not shift out of 2nd into 3rd.. took it back to my tuner he lowered the shift point .. and still did the same thing , it is only 2 mph more than stock tune.. so i dont know what the problem is.. is it in the tune or mechanical.. and also ,under normal driving conditions car shifts fine 1st, all the way through over drive.. has anyone had this issue?? suggestions?? thanx in advance
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    I would start by lowering the shift point MPH and RPM really low and see what happens if the shift still does not occur you may have 3-4 clutch issues
    Chicago(Bridgeport)
    01 T/A WS6
    it shifts fine driving conservatively.. and this never happened before the tune
    SUGAR LOAF PA
    blue
    2000ss
    Like I said try lowering the shift RPM and Mph AND SEE WHAT HAPPENS
    Chicago(Bridgeport)
    01 T/A WS6
    ok.. thanxs..ill try that
    Member supaxero's Avatar
    Sep 2008
    desert
    metallic pewter
    2000 Trans Am WS6
    Quote Originally Posted by MCCs WS6 View Post
    Im having the same problem, please let us know if it worked.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    I had the same problem with i first had the cam done, it wouldnt shift from 2nd to 3rd.
    it was a tuning problem.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Chicago(Bridgeport)
    01 T/A WS6
    in order to get it to shift we lowered the mph it shifts at.. this seemed to work fine.. my tuner set it to shift at wot at about 74 mph and it worked fine.. but i did have trans slippage issues so i had a hi-po 4l60 built.. now its shifts and hits.. real nice
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Did it burn up the clutch pack, band? what was the end problem?
    Chicago(Bridgeport)
    01 T/A WS6
    well.. i believe it was the band that was burnt up.. but i think it was more a tuning issue than anything..
  1. 98 trans am a4 not shifting into Park.
    By breakking in forum Firebird / WS6
    Last Post: 01-18-2012, 05:47 PM
  2. trans shifting
    By charlesss in forum Automatic Transmission
    Last Post: 10-18-2010, 08:13 PM
  3. Trans Am a4 shifting issues
    By GNICTRY in forum Automatic Transmission
    Last Post: 01-29-2008, 08:42 PM
  4. trans shifting problems??
    By jackmajic in forum Automatic Transmission
    Last Post: 06-23-2006, 04:21 AM
  5. 00 Trans am M6 Shifting problem?
    By 00BLACKTA in forum Manual Transmission
    Last Post: 12-12-2005, 12:33 PM
