Results 1 to 11 of 11
09-24-2007, 05:19 PM #1
!!!!Car wont crank!!!!! stuck in traffic
Ok i have a 96 trans am lt1, and i just went to the car wash to go wash my motor off and went to crank it after i washed it off and it took about 7 tries to finally get it crank, then it ran perfectly fine and i drove about 10 miles and stopped and got gas and it cranked perfect again , well got about 2 miles in the busy ass traffic and was sitting at a stop light and went to take off and my car just died and wouldt crank back up, i tried so many times the battery went dead, and got someone to jump me off and it would turn over and over and sputter and wouldnt crank. SO WHAT THE HELL IS GOING ON? Is it the opti , or fuel pump or what? i have no idea , just got home just now and tow truck just unloaded my car.................please anyone know whats up
09-24-2007, 05:24 PM #2Slow'er'Ass
- Thornton, CO
Opti would be my first guess.
09-24-2007, 05:29 PM #3
09-25-2007, 08:23 AM #4
water in the opti. Did you use hi power water on the engine at the car wash? Bad idea. I don't use any water and hi pressure water will blow into everything.
09-25-2007, 08:26 AM #5
just got to thinking that on my older cars with distributors if moisture ever got to the distributor you either had to wait until it dried out or take the cover off and dry it out yourself. You might get lucky and it'll dry out on it's own. Not familiar with the opti set ups but I do know they're a pain to replace and expensive. Well, that and they have a tendency to crap out on people.
09-25-2007, 09:05 AM #6
yes it was high powered water, and i was washing to enging to take it to show a guy to buy it so i could get a 2000 ls1 trans am,well needless to say i didnt get that far
09-26-2007, 12:41 PM #7
optispark, or alternator got wet in your cleaning process...
money is on the optispark since in '96 they came vented. good luck...
09-26-2007, 06:27 PM #8
so mine is vented? i am stumped here, i dont know if its fuel, opti, alternator
09-26-2007, 07:35 PM #9
yes it should be. i had a 95 z28 and the opti was vented...see if you can get a code reader and see what codes its throwing...
09-26-2007, 07:39 PM #10Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
If you have the time and don't mind trying it you should be able to test the alt at someplace like autozone. As for testing the fuel I am sure there is someone that has a safer way of testing then what I would try and do.
09-26-2007, 07:53 PM #11
well if my car ran , i could get it to autozone, but i got it towed and its sitting in my drive way and will not crank
ok so im back and getting back to the z28 that wont crank
By dany3350 in forum General HelpReplies: 9Last Post: 12-11-2012, 12:05 PM -
Help!Ls1 wont start unless i crank it 10 seconds
By Leeroyws6 in forum General HelpReplies: 56Last Post: 10-02-2010, 02:50 PM -
Wont crank. Security light on.
By yellowv in forum General HelpReplies: 1Last Post: 07-30-2007, 03:59 PM -
Trans am wont crank!!!
By camarostripes96 in forum General HelpReplies: 6Last Post: 12-19-2006, 01:56 PM -
Traffic.com monitors traffic in metro areas
By Motrv8d Steve in forum Almost Anything GoesReplies: 1Last Post: 04-12-2006, 06:23 PM
