Results 1 to 11 of 11
Thread: Nitrous main line
09-21-2007, 02:57 PM #1
Nitrous main line
Im short about 3 feet when it comes to the main nitrous line coming from the bottle, do they even sell custom line lengths? It's the larger size line than you see with most 100-150 hits. (i dont know the line sizes quiet yet)
09-21-2007, 03:30 PM #2
how did you route it? typically, the main line, which is a -4AN, is 14-16 feet long. depending on where you put everything, that should be plenty long enough.
if not, then you can just order whatever line length you need to finish it and get a matching male to male coupler to attach the lines together.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
09-21-2007, 03:35 PM #3
I had the bottle up on the back dash before, but now i have it sitting where the spare tire use to be, and ran the line down the pass. side of the car, but all my solenoids are on the driver side and wont work on the pass. side, theres a race shop right down the street from me who sells N.O.S parts and is a refill station, i'll just roll up into there and see what they got.
09-21-2007, 03:37 PM #4
i guess i need to see a pic. why can't you move the nitrous solenoid to the passenger side? it's how i have mine.
wife's set up
09-22-2007, 01:51 AM #5
My kit came w/ the throttle body spacer plate, and the ports are on the driver side of the plate, plus the kit taps into the end of the fuel rail on the driver side, so instead of having to extend 3 smaller lines, id rather just extend the main line.
09-22-2007, 04:14 AM #6
that explains it.
09-22-2007, 07:11 PM #7
Yes you can extend it pretty easily. You'll need a male to male -4 coupler fitting and buy a pre made 36" piece of teflon -4.
09-22-2007, 07:15 PM #8
Yeah I actually got a 3' piece from that race shop earlier! Soooo no worries!
09-25-2007, 06:33 PM #9
are all the nitrouis kits out there lines the same lengths or are some shoter?
09-25-2007, 06:35 PM #10
some 14 ft, some 16 ft.
09-25-2007, 06:36 PM #11
Nitrous fuel line pics please.
By slims00ls1z28 in forum NitrousReplies: 3Last Post: 05-02-2010, 04:25 PM -
Nitrous Line, Figuring Out The Size?
By ViperJ in forum NitrousReplies: 3Last Post: 11-30-2007, 05:29 PM -
By slims00ls1z28 in forum NitrousReplies: 1Last Post: 07-10-2007, 02:56 PM -
nitrous bottle/brackets/feed line
By 67turbocamaro in forum Parts Wanted / TradeReplies: 3Last Post: 12-15-2005, 03:54 AM
