Results 1 to 20 of 22
Thread: lowering spring question
09-18-2007, 05:36 PM #1Junior Member
- Mar 2007
- olean
white- 2000ss
iv got a 95 trans am ... i was looking at some eibach lowering springs to lower my car 1.8 inches... would i have to change the stock shocks or can i keep them and just put the springs on and be fine?... any help would e appreciated
09-18-2007, 05:47 PM #2
09-18-2007, 06:49 PM #3Junior Member
- Mar 2007
- olean
white- 2000ss
will my handling benefit alot or not really?
09-18-2007, 06:55 PM #4Trans Am for life baby
- Feb 2007
- E-town, Kentucky
95-black & 80-blue- 95 Trans Am and 80 TA
ur handling will get better with just the springs but it would be a new world with the spring and some hi-po shocks
95 TA A4, Black on Black C5 Z06 wheels, CAI, 160 powerstat, TB coolent bypass, TB foil, LT4 Knock Sensor, STB, SFC, Poly trans and torque arm mounts, flowmaster muffler, gutted cat, and hypertech tuned.
http://www.fquick.com/SexyTransAm
09-18-2007, 07:57 PM #5
eibach is the most likly change for springs and yes you will fell gain in turns and stuff and cornering. , but if your mostly doing the strip its not the best.
its just what you want really
09-19-2007, 02:58 PM #6Junior Member
- Mar 2007
- olean
white- 2000ss
if i lower it 1.8 inches will i be able to keep the stock tire size of 275 40 17
09-19-2007, 03:16 PM #7M6 King
- Mar 2006
- WI
- Blog Entries
- 1
09-19-2007, 04:42 PM #8Junior Member
- Mar 2007
- olean
white- 2000ss
thanks alot guys for all your help
09-19-2007, 05:19 PM #9
just let us know what you do and post pics
09-22-2007, 12:35 PM #10
where is a good place to get new eibach lowering springs, and to buy new shocks? a link would be appreciated.
09-22-2007, 08:03 PM #11
09-22-2007, 08:35 PM #12Crazy Canuck !
- Jun 2002
- Montreal, CANADA
better off changing the shocks at same time... if you were to chose only of the two to change, i'd go w/ shocks.
Eugenio_SS
09-22-2007, 08:47 PM #132000 Arctic White trans am, ws6 hood, ws6 air box, slp lid, slp smooth bellows, slp loudmouth exhaust,shift kit, rebuilt trans, LS6 intake, 3.73 gears, Shaner S3 p/p throttle body, and a tune . SFC. C6 ZO6 rims 18" in back 17" in front. Drilled and slotted rotors.
09-22-2007, 08:57 PM #14Crazy Canuck !
- Jun 2002
- Montreal, CANADA
shocks are meant to work w/ a given spring rate.
stock shocks are shit by nature anyways... given the choice on your springs, shocks that will suit it better can be selected.
Which Eibach you are thinking on ?
by the lowering values, it looks like you might be interested on the Sportlines. I strongly recommend against it. been there, done that.
There are a few threads on the prokit vs sportline comparison.
09-22-2007, 09:01 PM #15
so which do you suggest? which spring and shock combo do you suggest?
09-22-2007, 09:40 PM #16Crazy Canuck !
- Jun 2002
- Montreal, CANADA
what are you looking to accomplish w/ your car ?
how much more stiffness you want out of springs (stiffness and harshness is quite different)
what's the main use of the car ?
budget ?
09-23-2007, 08:35 AM #17
I don't necessarily want too much stiffness but a noticeable change! I do want to lower it but i have 18 inch tires in the rear and 17 in the front so i don't want it to affect that! the main use of the car is for daily driving but not that much. i do plan on getting a torque arm and sfc so i don't want to scrape over every lttle bump!! and as for the budget, nothing too expensive i do want a nice spring and shock setup, that is at a reasonable price. with all that said what is a good spring and shock setup that i should get?
09-25-2007, 08:43 PM #18Crazy Canuck !
- Jun 2002
- Montreal, CANADA
i'd say keep stock springs, get Koni SA for the front, installed in lower perch (lowers ~3/4")
get Bilstein HD for the rear, and rubber hose mod (lowers same amount), coupled a swaybars, it's cheap and car will handle great while increasing your confort.
If I were to do it again, i'd probably go w/ that approach or the Strano springs + revalved shocks.
10-07-2007, 02:23 PM #19
I was talking with a friend of mine who deals with Fbodys all the time. I asked him if I should get new shocks when I get a Pro Kit (1.4 inch drop) in the next couple of months. He told me that since I have a WS6 I shouldn't worry about it. The shocks on a WS6 and
SS are very good so it that is the case you might not worry to much. If you don't have a SS or WS6 you might want to consider it. Just my 2 cents.
10-08-2007, 01:57 PM #20Crazy Canuck !
- Jun 2002
- Montreal, CANADA
lol... shocks on SS and WS6 are identical to other fbodies, unless you have the 1LE option (level-2) which come with Koni's and different springs, or the SLP-suspension package option. (level-1) which comes w/ Bilstein.
WS6 shocks are the de-carbons and are quite shity... unless you have the FireHawk with the above mentionned packages.
Your friend might deal w/ fbodies all the time, but looks like suspension is not his knowledgeable area.
Question: BMR spring+lowering A-arm?
By 01SsRacing in forum Suspension and HandlingReplies: 16Last Post: 01-21-2013, 03:55 AM -
Wanted: strano lowering spring
By Blackbird WS6 in forum Parts Wanted / TradeReplies: 0Last Post: 09-10-2010, 06:02 PM -
Question: Best lowering spring/shock for daily driver...
By blackbird2001 in forum General HelpReplies: 5Last Post: 02-25-2009, 03:05 PM -
98-02 Lowering Spring Brand New
By 94 Formula in forum Western MembersReplies: 0Last Post: 08-30-2008, 07:52 AM -
Illustrated lowering spring Install???
By RDS in forum Suspension and HandlingReplies: 8Last Post: 09-28-2007, 09:19 AM
