    Chicago burbs
    sebring silver
    98 camaro SS
    LS1 and LT1 T56 whats the diff?
    Hey i got a questin i have a pritty munch new Lt1 T-56 and a blown Ls1 t-56 could i swap the gets from the Lt1 t-56 into the one for the Ls1??? any one know?
    R.I.P. LS1 LS1Power06's Avatar
    817, Texas
    03 Terminator
    Ive heard you cant but im not sure exactly why. Maybe bellhouses but couldnt you just change that? Im not sure but i knows theres def. a difference.
    RyAn
    Chicago burbs
    sebring silver
    98 camaro SS
    Ya thats what i want to find out because i have both trans couldnt i just take the guts like gears syco's and shift forks from the Lt1 trans and put them into the one for the ls1?
    metro Detroit area
    All the guts are interchangeable. You will have to use the same (LS1)front adapter, clutch housing and input shaft ( they are different and won't swap)if you are going back into aN ls1 application. The LT1 does not have a concentric slave ( why the adapter dif ) and the block bolt patterns are different( why the clutch housing dif). The LS1 input is longer( why you have to carry it over)
    Of course if you were doning this , you would also ( well I would) change the 3/4 fork to iron and install carbon -particle synchronizer blocker rings at the same time.
    Chicago burbs
    sebring silver
    98 camaro SS
    Thank you very munch 30thbird yeah i just ordrd up sum sycro rebuilt kits with the carbon blocker rings now i gotta get me some stronger shift forks
    metro Detroit area
    You will only be able to upgrade the 3/4( iron over aluminum) fork but I would suggest changing all pads( new forks come with pads) .
    metro Detroit area
    You will also need to re-shim( check the bearing end play) after such a swap.
  1. whats the diff
    By slim420832002 in forum Internal Engine
    Last Post: 08-03-2007, 08:03 PM
  2. 4L80E whats the DIFF from the 4l60e?
    By greatwhiteZ28 in forum Automatic Transmission
    Last Post: 05-24-2007, 01:28 PM
  3. whats the diff between ZEX and all the other NX kits?
    By greatwhiteZ28 in forum Nitrous
    Last Post: 02-28-2007, 12:52 PM
  4. Whats The Diff?
    By 01ls1ws6 in forum Firebird / WS6
    Last Post: 10-27-2006, 10:51 AM
  5. whats the diff in z06 calipers?
    By predator in forum Corvette
    Last Post: 08-28-2006, 05:48 PM
