Thread: Help removing caliper bolts
09-17-2007, 01:23 PM #1
Hey, I tried to change my rotors the other day, but I couldn't get the the darn calipers off. Apparently the bolts have 'lock tight' on them. I've almost rounded off one the bolts and I cracked a socket on another one. What's the trick to getting them off?
09-17-2007, 06:47 PM #2
First I would soak them in some pb blaster overnight. Then either get a short socket or a boxed wrench and get a breaker bar on the end of the ratchet or wrench. With a breaker bar you should be able to break them loose. Don't go slaming and yanking on the bar thats a good way to strip the bolt. Apply even steady preasure untill it breaks loose. If you stripped a bolt your probably going to need one of those craftsman bolt out sets they work pretty damn good.
05 PBM GTO
Cold Air Inductions CAI,Relocated IAT with omega,Slp Predator tune,Flowmaster axle back with H pipe,Custom tuned TCM.BC Racing coil overs
Sold 01 z28
09-17-2007, 06:56 PM #3
Also noticed your from the jacksonville fl area. Not sure if your on the other boards but some of us jax guys meet up once a month. Check the link for our next meet, bring anyone else you might like to bring, friends, family whatever all are welcome.
Jacksonville meet
09-17-2007, 07:07 PM #4Just me
- Nov 2006
- Broken Arrow, OK
If you are working on the driver side caliper, turn the steering wheel all the way to the right to get better access/leverage on the bolts. Turn the wheel all the way to the left when doing the passenger side.
09-19-2007, 01:55 PM #5
break to torch out!
09-19-2007, 07:04 PM #6
09-21-2007, 02:05 AM #7
I had the same problem... just changed my rotors and brakes yesterday.
1. Make sure your turning the right direction, you could be tighting instead of loosing. "Lefty loosy, righty tighty". This could be confusing b/c your working on the oppsite direction.
2. Place the wrench on it and give the wrench a couple of firm taps with a rubber hammer to break up the dirt.
Hope this helped... Worked with mine. Love the new brakes
rear caliper bolts
By cobra12345 in forum DrivetrainReplies: 3Last Post: 07-10-2012, 05:40 PM -
cts-v caliper mod
By 98TransAmWs-6 in forum Firebird / WS6Replies: 2Last Post: 05-03-2011, 04:10 PM -
brake caliper bolts...
By 02transamce in forum Firebird / WS6Replies: 4Last Post: 09-17-2010, 08:37 PM -
WTB Caliper brackets
By formergper in forum Parts Wanted / TradeReplies: 1Last Post: 07-30-2010, 08:19 PM -
Caliper guide/slide bolts stuck......
By Matto4785 in forum General HelpReplies: 11Last Post: 09-22-2007, 03:42 PM
