Results 1 to 3 of 3
    Driving as fast as I can dafaic's Avatar
    Waxahachie, TX
    97 TA M6
    wanting to go higher not lower and have a few question
    97 Ta making about 400 at the wheels.
    Hooker super comp long tubes keep me draggin
    Have about 3-3 1/2" of ground clearance
    Willing to drop upto $2k on suspension. I have stock suspension minus the boxed rear lower control arms.
    Wanting to raise the car 2" by way of air or coilovers.
    Prefer air as I won't have to crawl on the ground to change height.
    Also worried about pinion angle. If i raised the car 2" for everyday driving and dropped 2" below stock at the track what would the ideal pinion angle be?
    Tia for any ideas!!!
    lt4 hot cam, l.e. heads, gold 1.6rr, hooker lts, 3"ypipe, hookercatback, no cats, subframes, b&m ripper, k&n cai, msd6a-coil-opti, udp, tr55 g's, ta girdle, 4.10's, boxed control arms, Madz28 tune, specstg3, alum. elbow. No traction
    Junior Member Mr. Anderson's Avatar
    Jun 2006
    Independence, MO
    I installed air rides (cylinders, not bags) on my son's Civic del sol. The ride is very comfortable and fun. It definitely changes the geometry of the wheels, but only near full height and full lowering. He has been driving on them for a year and the tires are wearing evenly.
    After we upgraded the engine to a B16 DOHC V-Tec it doesn't feel stable when he gets on it.
    I'd go with coil-overs between the two.
    Waxahachie, TX
    97 TA M6
    damnit posted this huge post last nite and it's not here.
    After looking around all day I have three options
    hal front shocks with 1" of shock spacers to raise the front 1" with rear air bag spring helpers and new shocks like kyb
    hal shocks with 1" spacers up front and rear spring bucket spacer to lift car 1"-3" and some new rear shocks like kyb
    air ride front struts and rear air springs with an ArnottĀ® Quad Air Ride Suspension Control II or the air ride econo 4wheel system
  1. higher amp alternator
    By godless-phoenix in forum General Help
    Last Post: 09-22-2013, 10:58 AM
  2. Aftermarket Lower A-Arm question...
    By Szalkerous in forum Suspension and Handling
    Last Post: 12-15-2010, 11:18 AM
  3. lower tire press. higher ET, higher press lower ET???
    By greatwhiteZ28 in forum Drag Racing
    Last Post: 10-20-2007, 05:57 PM
  4. Lower A-arm question
    By Y2KPewterSS in forum Suspension and Handling
    Last Post: 02-15-2007, 05:37 PM
  5. Lower control arm question:
    By MarkuzLS1 in forum General Help
    Last Post: 06-10-2006, 06:47 PM
