09-15-2007, 07:49 AM #1
Need quick answer on O2 sensor wire extensions
I bought a highflow ypipe with cats but they are in different locations then stock, so the O2 sensor wires wont line up. My question is, what type of cables do I need? I checked thunderracing and they seem to have 2 main types of extension cables... 4 pin square and 4 pin flat. I cant fit under the car and I dont have a lift to see, plus I have to be at work in a few minutes but I want this ordered and done with. the cats on there now cracked and are rattling like mofos and i'm shootin shiney particles in my exhuast
Looks pretty but it smells funky and I bet its not makin the right O2 readings!!
1996 LT1 dual cat Trans
09-16-2007, 02:41 PM #2
Use your tire jack if your in a huge rush. Takes a few seconds to check.
The spare jack if need be.Last edited by Pntbll309; 09-16-2007 at 05:48 PM. Reason: Type of jack
09-16-2007, 04:25 PM #3
My 94 Z was the flat ones. I think the square type is for the LS1's. Not 100% positive though.
09-29-2007, 09:28 PM #4
Black LT1 Z28, your car is a 94(single cat) his car is a 96(dual cat) therefore...his front two o2 sensors are 4 pin flat, but his rear 2 are 4 pin square. check out jegs or performance center.
LS1 o2 sensor Extensions 24"
By bryceslu in forum Parts For Sale / TradeReplies: 1Last Post: 09-11-2010, 03:07 AM -
Need 02 sensor extensions
By FISH 99 WS6 in forum External EngineReplies: 1Last Post: 08-09-2010, 01:06 PM -
will i need 02 sensor wiring extensions?
By bgable in forum External EngineReplies: 24Last Post: 09-29-2007, 05:35 PM -
12" 02 sensor extensions (2 )
By GoFastGray in forum Parts For Sale / TradeReplies: 5Last Post: 07-05-2007, 09:38 AM -
Need ANSWER quick
By SexyAssFormula in forum Wheels and TiresReplies: 8Last Post: 06-14-2006, 08:25 AM
