Results 1 to 20 of 20
    with a LS1 2MuchFun's Avatar
    Dayton, Ohio
    2005 Cadillac CTS-V
    Z28; Just a name or does it have a meaning?
    always wondered, did the first z have 280ci or what?
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Just a brand name for the Camaro as far as I know.
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Member luvmyz28's Avatar
    Feb 2007
    Council Bluffs IA
    nbm
    99 z28
    I believe it has something to do with gm getting into the trans am series racing back in the late 60s. thats how the dz 302 z came up anyway. i could be wrong.
    old timer blue02Z's Avatar
    2002 Z28
    it first started as a SCCA trans am racer and had the dz 302. the first available ones came out in dec. 1966. there was only 602 '67 z/28's all were coupes
    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    When the first Z/28's hit the streets in 1967 they only came one way. HD suspension,4-speed,no AC,4.11 gears due to the very close ratio trans. with a 2.20 low gear.Average ET was low 15's but a good one with an athletic driver could manage some high 14's which was pretty quick back then. But of coarse was never a match for my 67 Chevelle SS 396/350HP 4-speed with 3.08 gears & wide ratio trans. With 2 ply red line tires at hilltop drag strip I took A-pure stock class trophy's at 13.80 & 108 MPH , and that was taking off in second gear cause low gear was useless.Later went to 3.73 gears -headers-and full slicks but never had a chance to run at the track again. Most of our racing back then was for money on the streets & yes some guys would run for pinks back then .
    Hamburg, Germany
    1998 Camaro Z28 A4
    i read that it was an internal gm code. the project before was Z27... no meaning to it, as far as i know.
    Hamburg, Germany
    1998 Camaro Z28 A4
    from camarosource.ca:
    The "Z" in Z28 was not chosen to honor the legendary Zora Arkus-Duntov as has been reported. The Z28 designation was at first nothing more than another option code, along with others like Z23 for the Special Interior Group, or Z87 for the Custom Interior. But Z28 caught on with the public and ultimately became an official model name. However, Z28s built in 1967 had no external identification other than wide racing stripes.
    PEWTER
    2002 Z/28 VERT.
    Yeah I think your probably right. I know in 1969 & 1970 the SS Chevelle engine was bored out to 402 CID but GM still called the SS engines " 396 " because that engine had such strong name recognition.The 396 was one bad ass engine.
    2002 Z28
    Quote Originally Posted by hamburger68 View Post
    the z27 was rpo code for the 350 SS
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Quote Originally Posted by Z ROADSTER View Post
    4.11's would have been 4.10 (10 pinion/41 ring), but that was an optional ration. 3.73 was standard. Posi wasn't even mandatory. Tranny could be M20, M21, or M22 but it had to be manual - no auto. No AC either due to the solid lifter engine (same with 396/375). Disc brakes were mandatory also. RS was an option also.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    70 on up due to smog concerns. 69 was still 4.094" bore. 70 thru 72 was 4.125" bore. They did keep calling it a 396 because of all the advertising they had invested in the name.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Quote Originally Posted by blue02Z View Post
    WRONG! SCCA T/A racer yes. 67 and 68 blocks are MO (federal emmisions) or MP (with A.I.R.) code. Only 69 blocks are DZ code. You are correct that the Z28 wasn't available until midyear (Dec 66) and only 602 were made. This was due to an SCCA requirement of a minimum 500 cars having to be available to the public to qualify for racing. Check this site for verification: http://www.camaros.org/index.shtml
    Lincoln, CA
    2000 Z28 Camaro
    It was Chevrolet's option number for the trans am racing package. It's like the Z71 4x4 pickup trucks. That's the factory opiton identification and Chevy decided it sounded tech and cool enough to use it as a model name.
    Dallas, TX
    2000 Firehawk #506 A4
    Quote Originally Posted by RagTop View Post
    Don't forget the Z24 Cavalier, Z26 Beretta, and Z34 Lumina, and of course...Z06 Vette.
    PEWTER
    2002 Z/28 VERT.
    Cool
    Quote Originally Posted by 67CamaroRSSS View Post
    The M20 tranny was a 2.20 close ratio only , & was the only trans. available in the 1967 Z/28 which required the use of the 4.11 posi-unit because the little high rev. engine didn't have much torque down low in the rev range & needed the 4.11's to get it moving. But once going would rev to 7000 RPM . Them's the cold hard facts.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    So you're saying that the Camaro White book along with all the experts are wrong???? I'll concede the "close ratio" M21 tranny in the 67 YM as the M22 wasn't available til 68 YM. The standard rear end ratio was 3.73 though and G80 (posi) was an option. Chevrolet (GM for that matter) never made a "4.11" gear ratio for the 12 bolt. Pinion is 10 teeth and ring is 41 teeth. This makes it a "4.10". I still stand by the info on this site: http://www.camaros.org/index.shtml
    the cake is a lie twozs's Avatar
    hopewell jct, ny
    black 01 red 73
    01 z28 and 73 z28
    ugh yea ! the camaro white book is wrong beacause it states that in 73 air conditioning was available on the z28 for the first time but not with a 4 speed and i own a 73 z28 with air and a 4 speed wide raito muncie. so if their facts arent straight about that then what else. it was my understanding that posi /373 was standard and posi 410 was optinal but allways posi on a z
    TN
    2005 GTO M6 Black
    2000 Z28 A4 Red
    Rear discs were also optional.
    Twin Beaches MD
    SOM
    '01SS Camaro,'09 Z06
    That gets my vote.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Yup option package number-------like WS6 is for Trans Ams.
  1. New Meaning for Rat Motor
    By Nowhereman in forum Almost Anything Goes
    Last Post: 12-20-2011, 06:45 AM
  2. Been meaning to get one of these installed...
    By Kramsdell in forum Almost Anything Goes
    Last Post: 06-23-2011, 06:46 PM
  3. New meaning of Rice
    By Knighthawk LS1 in forum Rocky Mountain Members
    Last Post: 01-01-2007, 04:00 PM
  4. what is the meaning of STH
    By ss~zoso~ss in forum Almost Anything Goes
    Last Post: 05-27-2006, 06:22 PM
  5. The meaning of 420 post !
    By Danger731 in forum Almost Anything Goes
    Last Post: 04-21-2006, 06:15 PM
