Results 1 to 13 of 13
    Junior Member KIXASS's Avatar
    MARYLAND
    How difficult to install ASP underdrive pulley.
    Besides the pulley and the belt, is the anything else I need? Some where I heard a new bolt??? Where would I get it or what kind? Also, are there any special tricks or tools to help with the ease of installation?
    I appreciate any and all the tips I can get.
    THANKS!!
    member HASTINGSRJ's Avatar
    Jan 2001
    Franklin, Mass
    00 SS Vert#0540/ 14 GMC
    you can order an ASP underdrive from Thunder Racing, TX speed, Speed Inc, or any one of the board sponsors.
    You will need a 3 prong pulley puller, you can pick that up at Sears $40.00 if I remember correctly (been a while since I bought mine)
    The new pulley should come with belts as well as a new crank bolt. Make sure you follow the instructions included with the pulley. If the pulley doesnt come with a new crank bolt, just go to your local GM auto dealer, parts dept, they are about $6.00 I believe. Other than that, its pretty simple to do....hope that helped
    rob
    Black 00 SS M6, vert, #0540 408ci
    DD 2014 Sierra All Terrain
    MARYLAND
    Why can't you use the stock bolt?
    LoudMouth SStriker's Avatar
    Westminster/Sykesville, Maryland
    2000 Trans Am
    Quote Originally Posted by KIXASS View Post
    Its my understanding that when they are torqued the bolt stretches and twists some. So it cant be reused.
    MARYLAND
    That makes sense.
    Senior Member JonB's Avatar
    Florida
    2005 GTO
    You can rent a 3 prong puller from autozone, unless you just want to add some tools to your toolbox. Alot of people use the old bolt to start the pulley and get it seated then put the new bolt in and set the proper torque.
    05 PBM GTO
    Cold Air Inductions CAI,
    Relocated IAT with omega,
    Slp Predator tune,
    Flowmaster axle back with H pipe,
    Custom tuned TCM.
    BC Racing coil overs
    Sold 01 z28
    Marylandistan
    2001 Trans Am (sold)
    If I remember right, you have to remove the radiator to get the pulley off. Might be wrong, been a while and the radiator had to come out for the cam install anyway. I would use a pulley installer tool of some sort myself, like this: http://www.ls1tech.com/forums/showthread.php?t=391883
    MARYLAND
    If the radiator has to come out, then I might as well just wait and have it installed when I do the cam.
    Marylandistan
    Actually I think I'm wrong. Don't think it has to come out now that I think about it. I'd get that tool tho. I know people that have messed up their crank threads pulling the pulley on with a crank bolt, big headache.
    Bragg NC
    Met. Sunset Orange
    01 SS
    As far as the bolt, It does stretch so it is a one time use bolt, just like the head bolts. If your using a "deep throat Puller" Dont let the puller contact the crank otherwise it may damage the threads, instead use a socket or an adapter inbetween, the two.
    J
    Member Ripper415's Avatar
    NY
    2002 Camaro SS
    i dont think the radiator has to come out, but if you're putting in a new cam you should wait to install the pulley anyway. everyone says its MUCH easier to do then.
    use an install tool and eliminate the possibility of stripping your crank threads. Easy to make and costs less than $20. Just need some metric all-thread, washers, and 3 bolts. I'll have to look to make sure but I *think* the all-thread is 16mm x 2.0 pitch. If you decide to do it the safe way let me know and I'll verify that size but I think that's it. I have some all thread in the shed I can cut and send you but I don't know how many bolts I have left.
    Florida
    2005 GTO
    The radiator does not have to come out to do the pulley.
  1. Underdrive pulley install question
    By KDZRGROWN in forum External Engine
    Last Post: 10-19-2008, 11:24 AM
  2. Underdrive Pulley
    By Sarge in forum GTO
    Last Post: 09-18-2008, 11:24 AM
  3. Underdrive Pulley-Does It Need OD Alternator Pulley
    By Eddie 70 in forum External Engine
    Last Post: 10-01-2007, 08:23 AM
  4. underdrive pulley install question
    By tx77015ls1 in forum General Help
    Last Post: 05-09-2006, 08:06 PM
  5. Squealing noise after underdrive pulley install...
    By bbfirebird in forum External Engine
    Last Post: 12-18-2005, 01:28 PM
