Results 1 to 10 of 10
    Member nate_the_great17's Avatar
    fortworth
    81 camaro
    2001 trans am ws6
    want to change exhuast system
    i have a y-pipe w/ mangaflow high flow cats and a flowmaster 80 series and i want to change it out and put and x-pipe and what type of muffler should i go with is it worth the money and would i gain any horse power from it and i would also like to take the cats off too
    Bragg NC
    Met. Sunset Orange
    01 SS
    Do you allready have lt's? If you get rid of the y pipe and put in an x pipe, you will pick up a lil more power and alot more sound. Most people go with the dump, setup because its alot cheaper. Exhausts shops charge around 600$ or more to run true duals. You can pick up some bullett mufflers. Check out Thunderracing.com, one of our sponsers.
    J
    fortworth
    81 camaro
    2001 trans am ws6
    thanks man
    fortworth
    81 camaro
    2001 trans am ws6
    would i gain any power if i take my cat of
    Bragg NC
    Met. Sunset Orange
    01 SS
    If you yank out your cats, you wont gain much Hp but a few. You can also pick up some cat bypass pipes, they bolt to your manifold and then to your y pipe, although you will throw a codes and the pipes are a little bit pricey.
    J
    Bragg NC
    Met. Sunset Orange
    01 SS
    If you yank out your cats, you wont gain much Hp but a few. You can also pick up some cat bypass pipes, they bolt to your manifold and then to your y pipe, although you will throw codes and the pipes are a little bit pricey.
    J
    fortworth
    81 camaro
    2001 trans am ws6
    thnx for the advice
    fortworth
    81 camaro
    2001 trans am ws6
    i have shorty headers on my car i was thinking on putting long tube headers on it, is it worth it or should i stay with my shorty headers
    old timer blue02Z's Avatar
    2002 Z28
    you will see more hp with longtubes, i did especially if you get a tune. i would personally get rid of you cats and get magnaflow mufflers, they make a bullet style i think. they sound great and last a longtime. since you are in tarrant county they have emissions so that might be worth noting. btw what part of fw are you from? i moved up here from decatur about a month ago, welcome to the board
    fortworth
    81 camaro
    2001 trans am ws6
    i live by keller, do know were fossil ridge is at, i live about 7 min away, do u think i should go with an x-pipe or i should stay with my y-pipe, and where does get their cats taken off around here
  1. What does it take to change my monsoon system?
    By 01SsRacing in forum Stereo and Electronics
    Last Post: 02-02-2011, 05:44 AM
  2. Full exhuast system..
    By snaggeltooth in forum Camaro / SS
    Last Post: 07-01-2010, 07:07 PM
  3. Will, SLP Lid, exhuast cut out Help
    By karpetcm in forum External Engine
    Last Post: 10-28-2008, 08:55 AM
  4. Which exhuast set-up?
    By hamptonwsk in forum External Engine
    Last Post: 06-11-2006, 10:25 PM
  5. Hooker system looks like crap, what should I change to?
    By Roastem in forum External Engine
    Last Post: 01-16-2006, 09:06 AM
