Thread: How should I spend it?
09-10-2007, 01:53 PM #1Member
- Sep 2005
- Southeast PA
Black- 2000 Z28
OK, I've got about 2000-2500 or so to spend on parts/labor for my camaro. Its bone stock right now. Anything that can be reasonably done in a weekend I'd probably do myself/with help from mechanic/gearhead friends. So that means no cam/head swaps unless you could the labor as part of the cost.
I'm definitely doing exhaust, so lets figure about 1000 there. That means I've got about 1000-1500 to go toward other stuff.
Suggestions, and price estimates?
09-10-2007, 05:01 PM #2Senior Member
- May 2007
- Bartlesville, Oklahoma, United
Bright Rally Red- 2000 Camaro SS #5075 M6
Id get a pair of SFC's. Parts-$100 Install-$100-$200
Lid-$100
09-10-2007, 05:31 PM #3Just me
- Nov 2006
- Broken Arrow, OK
LS6 intake $300-350, do the labor yourself, should be a 2 hour job roughly.
SFCs $150, $50-100 labor
Lower control arms, $100, do the labor yourself.
Lid $100, do the labor yourself, 10 minute job.
If you are an automatic tranny, look into a stall convertor(3500 range), shift kit and tranny cooler. $500 stall, $100 shift kit, $50 cooler. Get a couple of buddies, do it yourself.
Those mods along with the exhaust would put you in the 330-340 RWHP range and a mid 12 second car. If you are a manual tranny, forget the stall/shift kit/cooler and save the the remainder of the money for a 12 bolt.
09-10-2007, 05:55 PM #4Member
- Sep 2005
- Southeast PA
Black- 2000 Z28
Why do you suggest going right for a bigger rear? I mean, I know nobody's stock rear is fantastic, but isn't that some overkill? Also, what is the labor on the SFC, they're a weld in, no? I've got access to a welder, and someone who works in a metal shop for free, so I think I can get the welding in taken care of.
09-10-2007, 07:38 PM #5
Our stock rear's are pretty much garbage. They deside to self destruct under stock Hp let alone More. Some rear ends hold together for a while although some just give up right away.
Like Y2k said, SFC's are a good investment and keep the body straight. I would personaly reccomend the weld in. If you have access to a welder then you can save about 100 bucks on the instail. Thats the going rate these days.2001 SS, Its not the car its the Driver that matters....
Question: 3k to spend on t/a
By reaper ws6 in forum General HelpReplies: 17Last Post: 01-06-2012, 01:26 PM -
If you had $40k to spend....
By predator in forum Domestics and ForeignsReplies: 58Last Post: 02-13-2010, 01:35 PM -
$11K to spend......
By pinky93 in forum Forced InductionReplies: 44Last Post: 03-24-2008, 04:56 AM -
if you had 6k to spend
By third_shift|studios in forum Almost Anything GoesReplies: 70Last Post: 05-21-2007, 06:50 PM
