Results 1 to 3 of 3
    speedo
    Guest
    90mm ZO6 TPIS modified intake and Thottle body FS
    I have a ZO6 intake that TPIS modified to 75x90mm with throttle body for sale 879$ shipped or B/0
    This setup will be perfect for your stock cubed engine or more streetable larger cube motor without loss of low and mid range power like with the Fast 90/90TB setup.
    This will fit all 97+ Corvette with the cable Throttle body, (TB won't work with flyby TB) 98+ Trans-Am and Camaros, GTO and it will work on a LS2 with some minor modification to the injectors and rails.
    I am selling it because I went to direct port nitrous and had to go with the Fast 90. I have noticed some loss of low and midrange with my Fast 90 on my current setup with the swap.
    If you have any other questions just shoot me a PM. If you want pics I can send them to you or PM you the link...
    http://i27.photobucket.com/albums/c1...1/DCP_0530.jpg
    http://i27.photobucket.com/albums/c1...1/DCP_0525.jpg
    http://i27.photobucket.com/albums/c1...1/DCP_0531.jpg
    http://i27.photobucket.com/albums/c1...1/IMG_0625.jpg
    http://i27.photobucket.com/albums/c1...1/IMG_0628.jpg
    Thanks for you time.
    Sonoma GT w/416 L92/T56 HotRodV6's Avatar
    Humble Tx 77396
    1992 GMC Sonoma GT
    Im curious what kind of gain did you get with this setup over your stock intake and TB??
    Also, curious why this set up wouldnt work with the DP set you have? I plan to run an NX DP kit that has the nozzles that mount under the injectors and plan to run a 175 shot.
    1992 GMC Sonoma GT #492 of 806 built.
    Under Full Resto w/433 E85 L92/4L80E.
    1992 GMC Typhoon #1104 of 2200 built.
    Broken Crankshaft. New Engine Soon.
    2000 Olds Bravada
    Bagged 2wd Frame Swap
    L31 swap Planned
    Daily Driver
    speedo
    Guest
    I am not really sure since I did heads cam and this intake all at once. I would hate to say what a person would get because the more mods you have the more this will help.
    I went to the Fast 90 because It has the provisions for the nozzles and what I was really after, burst pannels on the Fast.
    After I did the swap I felt I really lost the low end and midrange, but it could be in my head. On top it does feel the same and this intake and TB combo.
    If you have anymore questions just ask away....
  1. Question: TPIS 90mm lS6 intake is it still worth it?
    By Blue28 in forum External Engine
    Last Post: 03-03-2011, 03:27 PM
  2. Wanted: F.A.S.T 90mm INTAKE AND 90mm throttle body
    By spooled88monte in forum Parts Wanted / Trade
    Last Post: 02-21-2008, 02:58 PM
  3. Replies: 5
    Last Post: 07-30-2007, 07:23 AM
  4. WTB LSX 90MM Intake and 90MM Throttle Body
    By XtinKt in forum Parts Wanted / Trade
    Last Post: 01-25-2006, 01:59 PM
  5. Thottle body and Aluminum Intake Manifold
    By Herb81 in forum Parts Wanted / Trade
    Last Post: 01-04-2006, 11:21 AM
